Question about Philips VR550 VHS VCR
Can't record from tv
I want to record some programes from tv set but I don't know how to do this ?!
  • 1 more comment
  • habachi saleh Aug 18, 2008
    please
    I have a video philips vr 550/07 and i want to record from a tv. set which is connected with a receiver
  • habachi saleh Aug 31, 2008
    still don't know how to record !
    you asked to know information about tv set :
    sony and it has outputs audio and video
  • Philips Master
  • 5,568 Answers
You did not mention the brand and model of the TV so it is unlikely we can answer your question.
If the TV is equipped with outputs for audio and video or a composite output, this should be difficult.
Many sets of all kinds involved with A/V use a fairly standard set of color coded in/outputs to simplify interconnecting them.
Posted on Aug 18, 2008
  • Steve Allison
    Steve Allison Aug 31, 2008
    We'll try again; I downloaded what was called a 'manual' - it isn't. More of a sales brochure (= useless)
    Please give me the following info:
    - Are you in North America?
    - Your signal source: Satellite? Antenna? Cable?
    - Which input are you using on the Sony TV? Is it plugged into a mating connector or is it screwed on?
    - Is there a threaded connector on the back of the Phillips?
    - If not, please describe what is available there and, if present, include the markings that belong to each connector.
    Although less desirable than some connections, if you can attach the receiver (output) to the VCR input (this would be the screw type connector on each), then, the same type from the VCR to the TV, you would have to set the TV's input channel to 3 or 4 (could be either) to view what is coming from the VCR and the VCR's tuner (selected for source) would then have access to the output of the receiver which would allow you to record what you are currently viewing.
Don't know how to set up for any tv need instruction booklet
don't know how to set-up or program the code (1047) for a RCA tv. using URC-3021 remote control
Jul 10, 2011 | One For All URC-3021 Remote Control
I have a vwm-400 Sanyo video cassette recorder. The clock on the recorder is set to the correct time! I programmed time recording for a set time to record a program on TV, but timed recording is not...
After programing/ feeding record time in VCR, press Timer button on VCR so it will go into standby mode with Timer indication. VCR will automatically turn On at set time and will record program of set channel.
Let me know if you have additional question.
Thanks.
Dec 18, 2010 | Sanyo Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Can't turn TV on with remote or with Power On button on the TV
the problem can be the flyback transformer or surrounding component. check if you how to do that . If you don't know don't do that because it is very dangerous.
Sep 23, 2009 | JVC AV-32120 32" TV
I MISPLACED MY USER MANUAL
You have to go the main menu and select record times, and day. Make sure you leave your tv set on, and on the channel that you wish to record the program on. You can set the start and stop times a few minutes before and after on the vcr, just to make sure you get the whole program. You can also set the vcr to record this program every day, any day of when ever you wish you can just manually hit "record on the vcr remote. Good luck, let me know how you make out! Thanks
Aug 12, 2009 | Televison & Video
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Recorded programs in english come out in Spanish
Make sure your TV hasn't been set for SAP (you'll find it in the audio settings menu). Second audio programming is often used to carry alternate languages, and if it's turned on you won't know it until you watch a program where it's being used. There may be a single button labeled SAP on the remote. If so, it's easy to change the TV setting without realizing it.
Feb 06, 2009 | JVC AV27F476 27" TV
I cannot get program recording with timer set.
Problem seems to be related to the "write protect" tab on the tape not being sensed. Is the tab removed? That would explain things there...accordianman
Nov 28, 2007 | Zenith VCS442 VHS VCR
Green screen on a LCD T.V.
if u can see other programs then the problem will be due to the signal fail the cable connecting may be faulty and it is very rare for a new player u check it with a new cable and change the pal and ntsc it may also make the picture correct
Jul 03, 2007 | Sony RDR-GX300 DVD Recorder
Philips VR550 VHS VCR Logo
123 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
