Question about HP-COMPAQ - 243891-002 (243891002) Power Supply
How can i start this without PC?
I would like to start this PSU (HP-COMPAQ - 243891-002 or PDP-117P) without PC, whichs pins shall I shortcut?
Thanks
  • 1,800 Answers
All what can i do is to give u this amazing article its me who wrote it, well u can benefit from my researches
http://compreviews.about.com/od/tutorials/ss/DIYPSU.htm
Posted on Aug 18, 2008
SOURCE:
Compaq computer power supply model HP-U250XC3 how to turn it on
what PC? none stated, just PSU.
what are you doing with that PSU
bench testing, it or what>>>??? we cant guess USAGE ever.
to bench test it use a jumper wire.
the 24 pin cable ATX2, jump pin 15 to 16, PS_on to ground.
that turns it on, so you can use a voltmeter to check each power rail pin.
http://www.pcdied.com/power.html
in inside PC, it must be connect to the MOBO
and then the MOBO power switch connected or it cant be turned on.
May 23, 2017 | Compaq Computers & Internet
Pdp 117p compaq not starting
Visit this site. It has detail descriptions about faults to Plasma displays. Pull up older posts there, or do a search by your TV brand name, at its search box. A very informative site indeed.
With this insufficient information posted by you, it is not possible to post a solution to your TVs problem.
Mar 17, 2013 | Televison & Video
Where can i buy a compaq presario power supply
Almost any standard ATX psu will fit this model, 86mm x 150 mm x 140 mm I would think. (PSUs come in standard sizes, most are ATX with depths into the case of 140mm upwards. Your old PSU s 140mm deep, so I should get one that also that deep. Higher powered ones can be can be as deep as 180 mm which wouldn't fit in your computer). It would be better if you bought a good brand one such as Antec, Corsair Silverstone, Seasonic, even an a Zalman or Akasa to name but a few, of at least equivalent power (it does not matter if it is a higher rated power, your computer will only take what it needs). Be certain that the PSU has enough of the correct type of connectors for your PC - Molex 4 pin power, minimolex for floppy if you use that, and SATApower if you have those, and 4 pin (I think for your pc) "P4" connector for your mainboard/CPU, and a 20+4 (20 pin with detachable 4 pin section for 24 pin m/b) pin motherboard connector. Be certain that it will accept the correct input voltage for your location (many will accept 90-240V ac now). You might try to get a second hand one.
12.April.2014
Jan 15, 2013 | HP Compaq Presario SR1750NX PC Desktop
Power supply not powering on
mine 2 psu running doesn't. false where knowing won't am i?
Aug 08, 2012 | HP Compaq 6000 Pro Microtower PC (NV504UT)...
Compaq series pdp 117p does not turn on. os their
sir go to the link elektroda.pl
1 open the supply,
2 check the ac voltage upto rectifire a
3 check the further dc voltage after the bridge rectifire
for
1 see if the ac is going upto rectifire
if not then remove the fuse that is covered with tape or if there is a resistance fuse , then take it out and replace
remember to change the fuse with similar value
2. if dc is formed,
check the filters and the diacs and diods in post sm transformer circuit
else write me again
if u solve the problem then thank me else send me internal picture
Dec 26, 2009 | Compaq Computers & Internet
Hp compaq dc 7100 psu 24 pin SLIM LINE
why wont you buy a new power supply or a plug that converts from a 20 pin to a 24 pin
Mar 31, 2009 | HP Compaq dc7100 PC Desktop
POWER SUPPLY 24 pin slim line colour code ,hp compaq dc 7100
normal white wire....?
white with red....?
brown....?
PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Mar 01, 2009 | HP Compaq Presario SR1350NX (PP196AA#ABA)...
Open Questions:
++++AmaZon PrImE ReFunD PhOnE NuMbER ``+1-++85O++-812+-+4OO9`` Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? ++++AmaZon PrImE ReFunD PhOnE NuMbER +1-++85O++-812+-+4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime?AMAZON PRIME Tech Support Number +1-85O**8I2**4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues.
Oct 20, 2019 | Amazon Computers & Internet
AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime?AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues.
See all HP-COMPAQ - 243891-002 (243891002) Power Supply Questions
Computers & Internet Logo
550 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
