Question about Garmin Nuvi 660 GPS Receiver
Wont power on
Hi I was using my Garmin yesterday and the battery went flat as it was not plugged into the lighter. so i plugged it in to the lighter but it would not switch on. The red light was on in the charger. Can you help please. Thanks
  • 53 Answers
Give it time to charge then try it... if this does not work hit the reset button with a needle and this should fix the problem you are having
Posted on Aug 31, 2008
Garmin nuvi 745
Yes, a Cellphone, Google Maps and a Power Block will give you about 5 days use!
You could also carry a small 12 volt lithium battery of the type used in alarms in a back pack, connected to a cigar lighter like this unit.
12VOLT RECHARGEABLE PORTABLE BATTERY POWER PACK 12V DC CHARGER LIGHTER...
Or this
Lightweight 12 volt portable battery station Lithium ion 8 8 Amp Hours...
Or you buy a GPS Sat Nave unit specially made for cycles.
Cycling GPS Units Amazon co uk
Garmin Edge 1030
Garmin Edge 1030 GPS black 2018 handheld colour gps
Nov 18, 2017 | GPS
No light on vehicle power cable
If this is a cigarette lighter plug, the fuse may be blown. Unscrew the top where it plugs into the cigarette lighter and check the fuse. But, more than likely the fuse in your car for the cigarette lighter is blown. Check the car fuse first.
Aug 18, 2012 | Garmin nuvi 1490T GPS Receiver
I havew a Garmin nuvi. Yesterday I was driving
Check the fuse in the lighter end of the cord.....it may be blown and the unit is not getting power.
Oct 26, 2009 | Garmin nuvi 260W GPS Receiver
Garmin went totlly blank during use.is there a
most Garmin's are powered by external sources which charge the device. the device has a battery internally and is kept charged by such a cable connected to the cigarette lighter socket.
If its a built in Garman then most likely its the fuse.
AndystUK
Aug 30, 2009 | Garmin nuvi 350 GPS Receiver
Garmin screen is all i get, then it turns off
try changing the batteries or placing the device on charge and unplugging it, if both those don't work go to the support section on garmin's website www.garmin.com/support/
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
Garmin gps 12 wont turn on.
Sorry to hear of the dead units. Are you using the correct power cable with a small hole in the centre of the plug? The GPS 12 is strictly limited to 7 volts only. The accessory cigarette lighter cable for this model has a circuit inside to drop the voltage from 12 to 7. Cannot be fixed. There would have been a plastic peg in the back of the GPS socket to prevent anything but the correct voltage Garmin cable being plugged in. Unfortunately these pegs are easily broken off. Yes, they are a good little unit even though well on in years. The next model up - the 12XL - can accept a wide voltage range and does not have the plastic peg.
All the best, Tony at KiwiGPS.
Apr 20, 2009 | Garmin GPS 12XL GPS Receiver
320 streetpilot Won't turn on only used 3 times how do i change the battery
plug your Garmin in the next time you are planning to drive for a couple of hours and let it charge, if not that then it is the connection wire is loose at the base of the unit...go to radio shack if your wire is bad....they have them there.
Oct 27, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin gps 296
If it does not show 'charging' when connected to power, then something may be wrong with the power cord. If it is the vehicle cord (the one with the cigarette lighter plug) check the fuse in the tip of the cord.
May 10, 2008 | Garmin GPSMAP 295 GPS Receiver
Garmin c340 went black and can't get it working
The battery was completely dead. I must not have had the cord plugged in to my lighter, or maybe it wasn't sitting properly on the cradle, and it was running on battery power. I found that when I charged it by the computer, it was ok. It is working with no problems, now.
Mar 10, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
57 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
