Question about SanDisk Sansa e260 MP3 Player
My PC doesn't read my sansa e 260
I have Windows Vista in my PC ,When I connect my Sansa e260 MP3 player, It appears like connected, but almost instantly , it disconnect, and start over again... an never stays in connected status. I tried changed the USB port but nothing.
The weird point is that I have another Sansa MP3 player... m240, the small one, that is recognized by my PC.
Please help me to resolve this problem.
I think it is that u need a program like samsung pc suit or somthing like that im not shure try it and it might work
Posted on Oct 05, 2008
I have Windows Vista and it says that it can't support the sansa e260
I would place the e260 in MSC mode first, as Vista should support this Sansa.
Unplug the player, then from the e260 do the following:
go to Settings, then choose System Settings then USB Mode & select MSC. Next, connect the E260, Vista should now see the player properly.
Mar 19, 2009 | SanDisk Sansa e260 MP3 Player
Sansa 260
this is how to do it READ EVERYTHING DONT SKIP THING
Switch your Sansa E260 to its Recovery Mode:
1. Make sure the player is powered off
2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface
3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button.
4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode"
5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above)
6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6.
Next, Apply the firmware for the E260 (your player should be connected to your PC at this time):
Step 1:
Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop":
http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Step 2:
Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred.
Step 3:
When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch
Step 4:
Power up your E260 and 90-99% of the time, it would boot up successfully.
Step 5:
Enjoy using your Sansa E260, just like I do. (I love this player)
sorry for so much writing it pays off read this to
) Unzip the downloaded zip file and extract the file pp5022.mi4
2) On your Rhapsody device, go to "Settings" -> "Mode" then select "Rhapsody"
3) With the data cable, plug the USB connector to the USB port on the PC, verify “Connected” is shown on the e200R display
4)On the PC, Check for device “Sansa e200 (E:)” under My Computer.
NOTE: the actual drive letter might be different
5) Drag and Drop pp5022.mi4 from your PC to the root folder of E: drive.
NOTE: Do NOT drop it to “Sansa e200R Rhapsody” device which is the MicroSD card slot
6) Unplug your Rhapsody device.
7) Your Rhapsody device will restart and perform a firmware upgrade and restart again.
When done, go to main menu “Settings” -> “Info” and verify the current version number.
enjoy
Nov 13, 2008 | SanDisk Sansa e250 MP3 Player
Driver
hi i need driver for sansa e 260 mp3 player
Sep 26, 2008 | SanDisk Sansa e260 MP3 Player
I have a sansa e260 and it connects and charges on computer and program can be located but computer is not reading that it is connected so can't sync it. Can you help? Thanks. Michele
I found another complaint similar to mine and someone had posted a solution, which also worked on my daughter's Sansa e 260.
I went to settings, then usb mode and selected MSC instead of MTP and computer instantly recognized the hardware and I could sync her music for her! Can't remember name of person who'd posted solution, but thanks heaps!
Sep 14, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e-260
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 04, 2008 | SanDisk Sansa e260 MP3 Player
Synchronizing mediafly with sansa e200 series
U can either use wmp or yahoo music player works or u have to change the files to mp3 or wma files
Apr 01, 2008 | SanDisk Sansa e260 MP3 Player
SANSA 260
Tried to reset the device to see if that will solve it..
Jan 21, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260
When it comes to deleting songs, I went on the program I use to get my music on and clicked on the sansa 260 and found my playlist. I bet if you connect your sansa and look around that program, you could probably find your playlist and start deleting.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
