Question about OKI Office Equipment & Supplies
When to change the ink
Hi!  We have an Oki Data C5800 that we use with our Mac.  When we go to print it says that the supplies are low and when we view the supply levels we see that the image drums are below the little grey bar.  Our question is when do we change the drums?  When it shows that the color is gone or when the color is to or past the little grey bar?  In other words, is the little grey bar just a warning that the ink will be gone soon or that it is now ready to be changed?
Thanks!
Lisa
    Renaissance:
    An user who is expert in 3 categories / brands.
  • OKI Master
  • 1,362 Answers
Its a reference point for you to see how much is left, it should still print but will get lighter as the toner goes down.
Posted on Aug 19, 2008
Error 980 on OKI C5900 fatal error
First, there is no model C5900. There is a model C5800. On the assumption that you are having this issue with a C5800 then the problem is media wrapped around the fuser. After cooling you can try to unravel or unwind the wrapped media but you may need to replace the fuser.
Jan 20, 2014 | Oki Electric Industry C5900N Led Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
C5800 printing vertical lines through pictures
The thin lines are caused by a worn out drum. Remove each drum in turn and look at the surface. It maybe hard to see the scratches and if so then send solid blocks of the primary colours one at a time and that will prove which drum is at fault.
Oct 28, 2017 | OKI C5800Ldn Led Printer
Hi oki 320 turbo printer started to print very light ,i want to change the ink ,but i do not know where to put the ink ,please help
There is now ink in the machine. You just have to replace the print ribbon. This is the small black box that is mounted to the printhead.
Jul 13, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Oki C5500 dont have TC/IP menu, do you help me.
Symptom:
Unable to reach Printer from local network or Printer falling off network and needs to be rebooted before being able to print
Cause:
ecblank.gif ecblank.gif ecblank.gif Resolution:
Install OkiLAN8300e Firmware 4.06 (C5500/C5800) or 4.55 (C6100) update using Oki LPR Utility
Are you on a Mac?
Mar 10, 2010 | OKI C5500n Laser Printer
OKI C5800 color problems
Open the top cover. using a clean soft paper towel clean each othe glass vanes that hang down between the drums that are attached to the top cover. I use Alcohol, and a different paper towel for each vane.
Oct 25, 2008 | OKI C5800Ldn Led Printer
Oki C5800 constant 172 fatal error
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
Apr 15, 2008 | OKI C5100n Laser Printer
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
