Hi, I have a Sony Vaio model SR150FN and I want to install a new TOSHIBA 500GB HD model MK5076GSX, the problem is that the BIOS can't see it, I put the HD in an external usb case, created a 500 GB partition, formatted that partition with quick and full format, took a long timetoo, and after that I made that partition an active one, but still the BIOS can't see the disk, Do you know why? Best Regards
Re: Hi, I have a Sony Vaio model SR150FN and I want to...
> put HD into an external USB case
> the BIOS cannot see it
Correct. The BIOS does not see "external" USB devices.
However, see if you can "enable boot from USB devices",
and change the "boot order" to include USB devices.
You may need to remove the old disk-drive, and install the new disk-drive in its place.
Then, put the old disk-drive into the external USB case.
Install Windows to the new disk-drive, and then connect the external USB case,
and copy all the files from the "old" disk-drive to the "new" disk-drive.
The VAIO VGN-T350 is a notebook computer designed and
distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit
that stores data, consists of many clusters of data that can be rewritten with
new data.
If you are looking for a memory capacity upgrade, or if your
old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the
use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other
peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive
chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in
place.
Gently lift the hard drive and its cage away from your
laptop and disconnect the data cord.
Remove the four screws located at the corners, and then
remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and
replace the screws.
Connect the data cord to your new hard drive and place your
new hard drive into its chamber.
Close the lid and replace the screw to complete the
operation. http://www.fonerbooks.com/laptop_1.htm http://www.youtube.com/watch?v=rg_GvaMunas Sony Vaio Hard Drive Replacement This might not be your specific laptop it might give you
an insight into the hard drive installation.
Restart your computer during the boot process you will see on the screen to press a certain key usually delete or F2 to enter setup Press and hold that key during the boot up process to enter BIOS if you need to change any of the settings using the arrow keys you can load failsafe or optimised defaults hope it helps you
According to the detailed specs on that model, it came with a 60GB
ATA-5 EIDI hard drive. therefore, you can use any ATA compatible
(ATA-5, ATA-6 or ATA-100) EIDE/IDE drive that has jumpers enabling you
to configure the drive as "Master". Western Digital Blue Scorpio and
Seagate Momentus lines both have models that will fit the bill. You
can find those drives at your neighborhood BestBuy or Staples pretty
easily. I don't know if the A25 BIOS supports 48-bit
logical block addressing (LBA), in spite of what toshiba says, If it only supports 24-bit LBA the
maximum drive size is 137GB. If it supports 48-bit LBA then you can go
as high as you can find drives available; usually 500GB. I suspect that
it supports 48-bit LBA because various online vendors list up to 250GB
drives for that model. The most important thing about the drive,
though, is that it MUST be jumperable as 'master'. A cable select only
drive won't work. Both the Western Digital and Seagate EIDE models have
jumpers. hope this helps but if you need anything else just ask:)
name and brand of ur laptop.U need to go the corresponding website for example asus.com/toshiba.com.When u are in the look for word download driver or word support.Then the model of your laptop as well as the name.Then follow the step.
