Have panasonic tv model ct-32sl32c is dead no power light or anything when you push switch
    Genius:
  • 2,920 Answers
Bad power supply you will need to take it in for repairs
Posted on Aug 18, 2008
SOURCE:
32'' Panasonic television. Power switch does not turn the set on.
1 It appears that connecting cable is faulty. Normally when you connect and push the power switch the standby light should lit. Try the cable on another appliance and see its function. Also switch on the TV and try to switch it on with your remote control.
Nov 19, 2009 | Televison & Video
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
Panasonic CT-36HX42F I turn it on and then, turns off
It seems that the electrical relay's, it getting completed is not able to create the high voltage required for proper display. Hence on switching it on, the power LED will immediately light up but since the circuit is not completed it switches to standby and then off. Get the relays replaced and make sure you connect the main power chord to a 15 Ampere rating wiring usually the line meant for A/c and hot water Geyser(called as high power line)..........sodeep
Sep 19, 2009 | Panasonic CT-32HX42 32" TV
Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Jul 14, 2009 | Panasonic CT-36HL43 36" TV
TV won't turn on. (Panasonic 1080i HDTV)
By the sound of it its a dead power supply im afraid :( It is very common for them models at that age very common... it may be cheaper to fix then buying a new one but ill let you decide that one but yea theres hundreds of people that have the same problem with them panasonic's bummer dude :(
May 04, 2017 | Panasonic CT-30WC14 30" TV
NO POWER OR LIGHTS WHEN POWER BUTTON PUSHED
Hello and welcome to FixYa!,
It sounds like the Power Board on you TV has Died, you will need to replace it in order for your TV to work again
Hope this helps --Full Str Pka
Dec 30, 2008 | Panasonic Televison & Video
Panasonic CT-36HL44J TV went dead, won't turn on.
have check for fuse? is your tv cord good?
Oct 24, 2008 | Panasonic CT-36HL43 36" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
3year old Panasonic ct-32sx12f dead?
Sure, Why not? It is worth the effort. If the set is 'dead', it is the easiest to repair.Only 'tampered' sets pose problems. It could be a simple blown Fuse, or the Power Regulator IC. This should not cost you more than $100-150 as Technician charges + 15-20$ for spares. It could also be a defective Horizontal Outut Transistor and short cicuiterd FBT, (tho' it seems remote), but if yes, add another $100. definitely worth calling a professional techie
Aug 22, 2006 | Panasonic CT-32SX12 32" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Ekse
