Question about ASUS DRW-2014L1T DVD-RAM Burner
Solid green light
Hi put in new asus 2014, have a solid green light but the drive won't even open.
Turn off the computer. There is a small hole underneath the drawer and above the eject button. Push hard into this hole with a long pin, or the blunt end of a long needle, and the drawer should pop open.
Posted on Nov 08, 2008
6ya staff
SOURCE:
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My new luggie scooter won't charge
I have to ask, did you ever figure out what the issue was? My mother's scooter is having the same issue.
Feb 26, 2013 | Free Rider 2 Freerider Luggie Compact...
I opened the asus dvd to clean it and when i reassembled it , it doesnt turn on and there is no power, the lamp is dead
Hi. Usually if this is the issue you can try this steps. 1. Make sure that you put the cable back on the way it was before. 2.When you turn the computer Go to Bios Set up F2 and check on the boot sequence if the DVD drive is detected . 3. Try to press the Eject button on the DVD while your still on the F2 option or BIOS. 4. If the DVD is not detected and won't eject on the BIOS and even if you re-seat again the cable it means that the DVD drive is already dead...
Apr 16, 2011 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
How should i plug the system panel connector correctly
Open your manual to page 1-30. Follow the illustration shown. "F_Panel". What is missing from the manual is the wire colors coming from your case. These colors do vary from case to case. If your lucky the case's wires to the MB will include a two pin jumper and they will be marked as such. (HD_LED, RESET, ECT). Most Asus MB's provide you with a F_Panel stand off. Like the picture provided;
If you notice in the pic above you'll find a solid white wire color. This wire is to be connected to the - negative side of the F_Panel MB or jumper block. Other wire colors such as solid blue, light blue, light green and red are commonly connected as positive +. The four pin internal speaker uses black as its - negative and usually red for positive.
Link to Asus for your board;
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Hope you find this helpful!
Mike
Nov 17, 2009 | ASUS P5PE-VM Motherboard
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
Computer will not boot up.
I have built several gamming computers, one with Asus and had good luck. What I do have is a power supply checker that I got from Tiger Direct that I use alot. To me a 450 watt PS sounds a little small . Sounds like it cant regulate the voltage, expecially the 5 volts. I have a master power supply (650 watts) that will hook up to any board or hard drive. I try it when I have this kind of problem. The only thing I dont like about Asus is that they have so many pins, so I would double check the pin settings.
Did the power supply come with the case.. If it did, change it. I have never had any luck with those. I really think they use 2nd hand ones for kits. Just my opinion GOOD LUCK
Nov 03, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
My pc is going insane and so am I!
You need to go back into your manual and take a good look at the pin configuration connected from the Mb to your case. ASUS has a great site to help installing a new board. Check this out: http://support.asus.com/troubleshooting/troubleshooting.aspx?SLanguage=en-us
Click on Motherboards than click on (Trouble shooting PC).
Dec 05, 2007 | ASUS M2V Motherboard
Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
ASUS DRW-2014L1T DVD-RAM Burner Logo
199 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
