Question about GE Profile WPSR3120WWW
GE Profile Model WMSR3110W2WW washer
When spinning washer smells like burning rubber . Some of my white
clothes have come out with dark brown stains.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
Your bearings may be going.. does it make a racket as it spins too.. bearings come as sealed units, when they break down oil leaks, hence the stains.
It will only get worse so have it sorted to save your washing.
sue
Posted on Aug 18, 2008
  • pamelaml May 27, 2012
    Can the bearings be replaced easily? I am a single mom and can't afford a repair man. I did have several loads with the brown stains and could not figure out were they came from.
Inglis royal 100 dryer
Front and real door felts needs to be replaced
Oct 06, 2017 | Dryers
What's your problemI have an inglis royal 100 model 1a 86600 The white clothes come out with brown stains on them. It is old but seems to work well. Could it be the front gasket around the drum? I
there either is a rust mark on the tub or under the agitator oil could be leaking out or metal is rotting where the tranny shaft comes up under the agitator but like you said it's old and parts are starting to rust out and decay
Oct 06, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Brown stains on clothes
Sounds as tho there is an excess of fabric softener build up on the inside of the outter tub. Try Filling with Hot water and bleach and let set for an evening and then turn back on and e tcontinue washing thru cycle.
Jan 31, 2010 | GE WHRE5260E Top Load Washer
Agitator spins tub doesnt
GE USUALLY PUTS THE NUMBERS UNDER THE WASHER LID ON A METAL TAG. BUT I HAVE SEEN THEM ON THE REAR OF THE WASHER WHERE THE HOSES ARE LOCATED
Sep 16, 2009 | GE Profile WPSR3120WWW
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore 44102 Front Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine spins slowly and smells of burning rubber
The belt could be worn and will be slipping on the pullys, as it spins up the rubber , rubs against the pullys and that is what creats the burning rubber smell, the belt needs replacing.
regards jonno
Apr 21, 2009 | GE WBSR3140DW Top Load Washer
Stains on clothes after washing
This sounds like the infamous "Frigidaire Flaw" (they make some of GE's washers). The likely culprit is that the bearings on the drum's spindle are leaking.
To diagnose, call a repair man, or pull it out and remove the back cover. If you see brown streaks from the center spindle - that's it.
Repair is cheap if you can do the work yourself (inner and outer bearings), but $300+ for a technician
Feb 09, 2009 | GE WPXH214A Front Load Washer
Front loading washer leaves stains
This often is called "lint" but is really a "whiting" left by un-dissolved soap and can be seen at it's worst on dark colored clothes. This is made worse in a colder climate where the cold water entering the washer is much colder than normal. Things that can effect the quality of the finished washed products.
Too much soap: ( we have a test for this further down the page ) If you follow the manufactures instructions on the box, then chances are you ARE using too much soap. They like to sell you their product, I find cutting usage in 1/2 of what the box says will still wash good and also cut your chances of getting "whiting" on your clothes.
Nov 03, 2008 | Frigidaire GLTF2940ES Front Load Washer
Won't spin with clothes in it.
sounds like a tired washer, it may be cheaper to purchase another for a couple hundred bucks
Jun 14, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
197 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
