Canon MP600 Have disconnected my printer with intention of having to take it for repair until I opted to contact Canon. Cannot remember exact message other than does not recognize the cartridge I was putting in and showed a U 1--{can't recall the last two numbers}.
    Genius:
  • 3,422 Answers
Did you twist off and remove the orange protective cap from the bottom of the cartridge? Once you do this, press it in until you hear it click.
Posted on Aug 18, 2008
  • Priya darshan Aug 18, 2008
    The error is U150.
    You will have to replace your ink tank actually.So please contact
    canon.But there is also 1 home remedy which you can try just unplug all
    the cords of your printer for 30min and also remove all the ink
    cartridges.After 30min plug all the cords as well as install the
    cartridge and see if you still get the error.If you still get the same
    error then contact canon and get your printer replaced if it is under
    warranty or get your ink tank replaced.
    If you need anymore help let me know.
SOURCE:
Error 6b10
Hi there!
Here's what you can do:
1. Press ON/OFF switch to reset the multifunction device 2. Press Stop/Reset and ON/OFF to reset the printer 3. Try to check for jammed paper. click this link and under service & support type paper jam http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport 4. The MP600 may require repair
If you will still receive the message you can check this link for your model or contact the customer service http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Hope this helps!
Mar 29, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Shows error message 6000
You should try to reset the unit.
To reset first switch off the unit then Disconnect the unit from power supply/batteries then disconnect any other units connected to it, after that Leave it disconnected for 30 minutes. It should reset itself then start again.
Try this:
1.Press ON/OFF switch to reset the multifunction device 2.Removing paper jams MP600 3.The MP600 may require repair
Oct 27, 2010 | Canon Office Equipment & Supplies
Cannon MP600 printer shut itself down during printing operation . Pressing ON/OFF button will not turn it. I checked connections and power source. Still, no reaction.
Re: "Cannon MP600 printer shut itself down during printing operation ."
If a Canon inkjet printer is turning itself off, then problem is either control board or power unit. When this happens printer is often considered beyond repair, and in any case it must be tested by a technician to find out the problem.Repair involves testing volts out from power unit and testing components on main board.
Considering that the MP600 is quite an expensive inkjet, I suggest contacting Canon support and asking a quote on repair.
Here Canon support pages:
Canon U.S.A. : Contact Us
Canon U.S.A. : Support
Canon UK - Support
Canon South Africa - Support
Aug 30, 2010 | Canon Office Equipment & Supplies
Carriage assembly canon mp600 printer ink chip
It may well be cheaper to replace the printer than pay for the repair.
Dec 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mp600 printer
MP600 Easy fix for unrecognized ink cartridge
Jul 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Scangear - scanning problems with mp600
windows XP instructions.can be easily applied to other operating systems
-turn printer/scanner on
-go to control panel
-click on system
-click on hardware
-click on device manager
-click on imaging devices
-right click on canon mp600 and choose updat driver option and then after that is done.click on scan for hardware changes
(below images provided)
this should make sure scanner work.. but if it still doesnt work then go back to the device manager and check if there are any hradwares with a yellow question mark beside them.if there is then right click on them and click update driver.
if that does not solve the problem try reinstalling the CD or go to the canon MP00 web page (google it) to dowmload the printer/scanner drivers. and repeat everything until it works or until you give up =). hope it all works out bye!
Apr 02, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon pixma mp600
If its still under warranty send it back.
Solutions for error code 6800 Issue: Error code 6800 appears on the display (multifunction printers MFP)
1. Contact Canon for 6800 error - MP600 2. The MP600 may require repair
Oct 28, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Open Questions:
49 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
