Mitsubishi VS-50501... When I press the one switch the green light appears briefly and I hear a click and the set won't start.
    Genius:
  • 2,920 Answers
Its in your power supply its shutting the tv down
Posted on Aug 18, 2008
Mi problema es con mi mi televisor mitsubishi vs-50501 enciende y cuando va a entrar la imagen se apaga a veces si entra y se ve medio rara como que tiene dos imagenes un poco separada o se ve la imagen...
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Dec 19, 2013 | Mitsubishi VS-50609 50" Rear Projection...
I need a new Lamp. what is the parts number for a mitsubishi rear projection model number VS 50501
Hello.
in VS models there is no such a thing as a lamp. Your TV have 3 CRT tubes (picture tubes) each of them dedicated to Green, Red and Blue part of image accordingly.
It is not the part that you can easy replace by yourself and it cost new around $600 and just to refurbish existing one around $320.
But you have to refurbish all three of them at the same time. So we are talking about $1000 just for parts, not to mention enormous effort to align everything back together.
If you have bad CRT in your TV - I would advise just to trash it and invest in new one.
Lamp is replaceable in DLP projection Mitsubishi TV and it is next generation of TV"s. Model number starts with: "WD".
If you still insist on part number - I need to know what color of CRT you need - they have different part numbers.
Best regards
Russ.
Aug 18, 2010 | Mitsubishi VS-50501 50" Rear Projection...
I have a Mitsubishi VS-A50 projection tv, it has a green line looping down from the top of the screen and the color is bad. Can it be fixed of worth fixing?
The best thing to do is have a Service Tech come out, and see if he can answer that for you. Your problem may be something simple. Some adjustments shouldn't be to expensive on this set and worth it.
Oct 24, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi 50inch TV Turns off right after I turn it on
tv is in shut down.could be several things.call a repairman.
May 10, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50501 no picture sound works great
Odds are real good that the solder connections on the deflection yokes are bad. Go through the front access panel and with a small mirror look and the back side of the connector on each yoke. The top two pins of each will probably show 'ringed' solder connections.
May 07, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Vs-50501 50inch projection with no picture only sound!
Are there any other symptoms like blinking lights on the front or just no picture? This could be as simple as a few capacitors being bad or something more severe. Can you solder? Do you feel comfortable working inside the set where there are potentially dangerous high voltages present even with the set unplugged? Let me know and we'll work through the diagnostic process and hopfully resolve this.
Thanks,
Dan
Dec 31, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi VS-50501 - Black Screen
Is the power light staying on? If so press imput and menu together for 5 seconds to see if the set will blink a 2 digit repeating code. If that doesnt work. Check for CRT coolant leaks on the boards. This seems to happen alot as do faulty capacitors. Coolant leaks will be located on the chassis directly under the tubes they can cause corrosion and prevent your set from starting especially in the VS models.
Dec 30, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi VS-50501 TV turns off by itself
First check see if timer is set to come on by going throu the menu. If not then check Service Menu by pressing Menu2357 and check in there for timer on or off
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
