Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Code letters appear on screen
Occasionaly get letters in white on black background like FxFxFxFxFxFx. Changing chanels makes it go away. Is this TV related or Cable Company related?
  • 10,594 Answers
It is cable company related display because if it would Tv related, will stay all time at screen.
Posted on Aug 18, 2008
How to I reverse the background color?
Here's a Youtube tutorial on how to "reverse" the colors:
Sep 02, 2014 | Cell Phones
Fading colour
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | ViewSonic VA1703wb Monitor
Change background from black to white
Which operating system ??
Is it for computer background or a program ??..
Make a Black Background White
The desktop appearance of a computer equipped with Microsoft Windows XP, whether PC or laptop, can be customized easily.
Users can change background color, background image, frame color, font size and the arrangement of desktop icons.
Five easy steps how to change the desktop background color from black to white.
Changing Background Color
Right-click the mouse on any open portion (i.e., non-icon) of the desktop, which will open a menu. Select "Properties" at the menu's bottom, which will open the "Display Properties" application.
Click the "Desktop" tab at the application's top.
Click the down arrow next to the "Color" button, and select the white color.
Click the "Apply" button, then click "OK" to close the application.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_background_color.mspx?mfr=true
Aug 30, 2013 | Computers & Internet
White line appears in the middle of the screen
please describe the issue better cause it doesn't make sense..are you saying that your screen background is black no matter of the picture you choose??or that the image of the monitor is just showing a black screen??in the case I sescribed ..if the operation system seams to work but you can not insert any pictures anymore on wallpaper and it is black ..and a genuine advantage program is inserted a banner in the tray system ..(right ) ..this is a case that yous windows is not genuine and the warrning was placed after you check it on a installation ...to get rid of it ...just make a search in the start for a file named..WgaLogon.dll ..and after you lcate it ...rename in by changing a letter in th emiddle (ex: WgaLogTon)..and restart the computer ..after this the functions will be right back ..insert another walpaper and go on ..
If you are talking about the image being just a white line in the middle and the rest is black like it is shut down..than the issue is caused by a condenser burned on the image board..you should have it checked and changed..
Jun 01, 2010 | Dell E551 15" CRT Monitor
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
A black box stay on the screen covering,
turn on closed captioning. this is the only way we have been able to save the tv. after a few days we were able to turn it off again and the black box was gone.
Dec 05, 2009 | JVC Televison & Video
Printing white letters with black background..
you need to select the right tape for your machine. You can't change how it prints except by changing the tape. Brother has many colors to choose from.
Jul 14, 2009 | Brother P-Touch 1180 Label Printer
White objects (especially text) on a black background produce a white halo effect around the white lettering. When playing a PS3 game I noticed that the blue color appeared black, as though I had no blue...
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 27, 2008 | Philips 9P6040C 60" Rear Projection...
Black Box at bottom of screen
The text mode has been activated either thru your cable/satelite box or your tv's. It is activated because the closed caption portion. If you think its because of your channel providers call them for the process to deactivate it . If it's your tvs check your menu's to make sure the closed caption portions are turned off. Good luck
Feb 22, 2008 | Symphonic SC519DD 19 in. TV/DVD Combo
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
81 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
