Question about Amana Dryers
Amana Dryer LG8409W2 - The dryer heats for a few seconds then runs cold. The dryer has been cleaned as well as the vent and still no heat.
    New Friend:
  • 37 Answers
Karenl46 -- Flame sensor has to "see" proper flame in order for gas burner to stay on. Safety solenoid engages (shuts off gas) when flame light not detected. Check window on sensor (1:30 CW position) on burner tube. If you still have problem after cleaning it, then refer to URL below. -- SWT
http://forum.doityourself.com/kitchen-laundry-home-gas-appliances/350993-another-gas-dryer-no-heat-failure-rates.html
Posted on Aug 05, 2010
SOURCE:
Relatively new dryer not heating
Make sure the vent is clean. may have to check/replace the heating element.
Dec 26, 2013 | Amana Dryers
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2012 | Dryers
I have an Amana dryer Mod. ALG649RAW. Turn dryer on ignites than flames, but after a few minutes goes out, it will again ignite, but won't flame. Is it overheating? The dryer is vented underground about...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 28, 2010 | Amana Dryers
I HAVE AN AMANA DRYER MODEL LG8409W2. DOES THIS MODEL HACE A PILOT LITE OR DOES THE HEAT FLAME COME ON WHEN YOU TURN ON THE DRYER?
Your dryer has an ignitor that lights the flame...
here is the part...
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LG8409W2-%3d%3di1194687&PartID=1194687
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 05, 2010 | Dryers
Hi, i have an amana dryer, model LG8409w2. it is running but has no heat. is this a gas dryer? and how do i get into it to see what's wrong. thanks
Hi, to tell if it is gas or elect, just pull it out some and look behind it. A gas dryer will have a galvanized pipe with a gas flex line and shut off valve going to it. If electrical, it will have a large diameter cord plugged into a large round plug much different then a regular receptacle. It sounds as though it is a electric dryer as it is running. A gas dryer will have a regular plug on it to. If no heat, it could be a number of things that are wrong. The heat strips are located at the rear of the dryer behind the panel. You will need to unplug it and pull it out to do this. Give yourself lots of room with a strong light to work with. The heating element has several coils of wire lined up in a vertical position. Look them over very good for a break in any part of these coils, look very carefully to find one. If you do, you will need a new one. Take the model, serial, and name to a appliance parts house to get one. If by chance it is gas, make sure there is gas to the unit and the valve is open. Shut off the valve and take loose the line. Crack open the vale a little to hear and smell the gas. There is not much you can check on a gas dryer but this, that's about it. It may be the ignitior, a thermostat ect. I am sure you have a electric dryer, so check the element and clean all of the lint from the unit. Get back to me on this, so we can go further if needed.
Sincerely,
Shastalaker7
Jun 12, 2010 | Dryers
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Dryers Logo
324 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
