Question about Sharp R-1505 Microwave Oven
Door Won't Close
The door won't stay closed and the microwave won't turn on. The button to open the door is stuck in the open position (pressed in) and the button won't pop out when I try to close the door, so the door won't stay closed.
How do I remove the panel where the door opening button is located so I can get to the release? Is this my problem?
Ken Anderson
[email protected]
  • sragav Apr 25, 2009
    I got the panel off easy enough, but I can't tell why the button sticks. I even took the button out, but it seems to be that the plastic parts just don't fit together properly and are rubbing against each other. This is a new problem, and I've had the microwave for 3 years so I don't understand why the parts should suddenly start rubbing. I ordered a new button. I hope that will work.
  • Anonymous Mar 24, 2014
    No power panel on when door closed
  • Sharp Master
  • 9,174 Answers
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site. The best place to order Sharp parts is Tritronics.
You can usually find helpful exploded view diagrams and order parts for most non-Sharp models by entering your full model number here.
Posted on Aug 19, 2008
SOURCE:
Door stuck shut. Pushbutton does not work. How can I get the door open for repair?
Jo. you may have to remove the hole cover, to access inner latch mechanism, where you can manipulate the latch with long screw driver.*** before attempting this, unplug microwave for an hour***
press the helpful button. link below may help...
Microwave Door Won Open
Jan 25, 2016 | Microwave Ovens
Just today, the turntable won't stop turning when the door is closed.
have you pressed the stop button twice when the door is closed to exit the program set for cooking
Dec 17, 2015 | Microwave Ovens
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
Won't whut off when open door
The microwave running with the door open can be dangerous.
It's most likely the switch in the door stuck in the closed position. Or it has failed/broken in the closed position.
Sometimes the switch is just a button sticking out of the cabinet where the door pushes on it when closed -- sometimes the door latch pushes on a switch inside the latch receiver in the cabinet.
If cleaning around that switch doesn't solve the problem, you should take it to a repair shop.
Apr 28, 2009 | Microwave Ovens
The microwave will not turn off.
it sounds lioke the relay is stuck in side on the control board
the one that has the display on it need to replace are service it
Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Door Won't Close
What usually breaks is the door open lever, but sometimes there's just a grease buildup around the door open button.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's a Sharp or Kenmore, you can usually find exploded views and order parts by entering your model number here at the Sears parts site.
If you still have trouble, please reply back with your model number so we can help you.
Sep 21, 2008 | Microwave Ovens
Microwave Ovens Logo
189 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Ekse
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
