Question about LG Cell Phones
My battery on my LG viewty keeps going flat fairly quickly and once it has charged it also takes a while for the phone to load up when it gets turned on.
  • 35 Answers
Batteries go bad from exposure to water, even enough humid days can cause them to god bad. Some LG batteries have a little window/sticker on the edge of them. If its white it has not be exposed to water/humidity if its pink hash marks it has. I suggest looking on E-bay for a new battery. They are usually $40 at the store, and $5 on E-bay. That includes shipping from Korea.
Posted on Aug 19, 2008
My phone battery goes flat after 4 hours, i have the powersave on, bluetooth off, plane off , i have replaced the battery and its still the same
Oh dear. 4 hours isn't going to get you far thru the day. With the battery in fair health it should still last you all day with regular use (at least). Due to the nature of rechargeable batteries, the battery life with gradually get lower as time goes on. As a rule, it should still hold 85% of it's original charge after 1 year.
If you are getting less than this and you have had it less than 1 year, the manufacturer (LG) should replace it under it's warranty (in some countries you may have longer)
Further warranty information, and to submit a warranty claim, Visit the LG support page or refer to the original manual. LG KU990 Support:http://goo.gl/u57P9
Batteries are also available at amazon and eBay (be careful to avoid fakes)
Good luck
Mar 13, 2011 | LG KU990 Viewty
I replaced LG 800 - 800mAh Battery with a 1000mAh battery but the phone will not take a charge.On attempting to charge the screen & keypad flash on and off .Returning to my old battery everything works...
Hi, the problem you are having is with the new battery, their is a chip in the old battery that matches exactly with the phones make and model, now as the new battery is slightly different the phone is not picking up the signal and is going into safe mode to prevent damage being done by a battery that could be over powering the phone, if it was an older phone it would work as their is no chip in the battery but these newer phones have to match exactly with the correct parts else it will just put itself into safe mode to prevent any further damage being done by over powering the phone.
all you need to do is get the same battery as the one that was in the phone, if you take your phone to one of those independent phone shops they may be able to match a better battery up for you that will last longer in your phone.
now here is a tip
when you get a new battery its best if once a month you let it go totally flat keep switching the phone on until it wont switch on any more, then give it a full charge, doing this prevents bad cells forming in the battery and this will keep the life of the battery at its best, they dont tell you this when you buy the phone but they should do.
if you never let the battery go totally flat then this causes the cells to not charge properly and then this causes bad cells to form then when you charge the battery the cell wont get a full charge and then the phones battery life will decrease so let the battery go totally flat once a month and this will keep the battery life at its fullest and will keep your phone working for longer.
let me know how you get on or if you need further assistance ok
please rate this solution as i have a whole page of unrated posts, thanks
Nov 28, 2010 | LG KG800 Cellular Phone
Battery dies out very quickly. Sometimes, the phone will just shut down automatically.
Batteries (of ALL kinds) have limited lifetime, and it seems like your has reached to it's end!
I recommend you change the battery with a new one.
Proper care of the batteries may help extending it's lifetime. Keep the cellphone in a cooled temp. (if possible) and try no to overcharge the battery too often (means, disconnect when battery's full!).
May 10, 2010 | LG KU990 Viewty
My LG rumer 2 phone has lots of issues and its not that old.
if the battery goes flat quickly it means its not holding charge you need a new battery
Apr 04, 2010 | LG RUMOR Cellular Phone
Charging problems?
i am not sure it can be solved if you damaged it by dropping it.
however, if it is a battery that runs out of charge quickly i have a few suggestions. i have the same phone and it's a general complaint from serveral users that the charge runs out very quickly.
you can solve this by
- ensuring bluetooth is not on all the time
- don't run too many apps
- turn off 3G
- reduce time on internet
- change the settings for receiving emails
- don't have the backlight on full
- reduce the use of video/camera
all the above things take a lot of the battery charge.
yeah, i know - i kind of reduces the joy of having a camera with all these functions if you have to have them switched off!
the other thing i have found is that if i charge my phone from my computer via the USB wire (as opposed to using the mains charger) i get about 3 times longer battery life. I am not a tecchie and i can't explain why, but i just know it works for me.
best of luck
Sep 02, 2009 | LG KU990 Viewty
Viewty's battery loses charge very quickly
with rechargeable batteries you have to fully charge it up then completely run the battery dead for the first 3 or 4 times this is what extends the battery life. I have had an LG viewty for 16 months and only charge my phone twice a week. this is a golden rule for all rechargeable batteries
Aug 19, 2009 | LG KU990 Viewty
LG Viewty battery discharges quickly .....
Charging duration does not connect to battery lasting duration in any way.Optimal charging time is 3 to 4 hours.your battery will drain soon if you keep your touchscreen pressed continuously in your jeans pocket.Keep bluetooth switched off. Reduce the brightness of your mobile display. Play music threw headphone rather than using loudspeakers.
Jul 19, 2009 | LG KU990 Viewty
KU990 Viewty's battery loses charge very quickly
I saw on another forum two good tips.
1. Do not use a case with a magnetic clip.
2. Take off the battery cover and put tape over the two small etched squares that you can see one at each end on the inside of the cover.
I did this and up to now my battery has doubled its life. Still two bars after 1.5 days of medium use.
Terry
Mar 28, 2008 | LG KU990 Viewty
Cell Phones Logo
111 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
