Question about Samsung S630 Digital Camera
Camera lens stuck
Hello I have put new batteries in my camera and my len will not go back inside. It been like this for a couple of days please help/
    Sergeant:
  • 359 Answers
Push lens assembly back in with your thumbs until you hear a click.
Posted on Sep 02, 2008
Can you clean the inside of the lens on a digital camers?
take the batteries out and put the camera somewhere warm for a couple days it should work.
May 21, 2014 | GE Power Pro X400 Black 14MP Digital...
Batteries Dead and lens wont retract.. I just got
There are some cameras who give problem when they are new. Give it some time i am sure it when the battery is on the move it automatically repaired.
Aug 19, 2013 | Olympus SP-820UZ iHS Digital Camera, 14MP,...
Will not power on. new batteries installed.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Canon PowerShot A95 Digital Camera
Camera just stopped. lens out. won't respond at all. new batteries and card.
That is typical of a board failure inside the camera. It can also be a bad contact on lenses if your camera supports them.
About all you can try is remove the batteries and cards for a couple of days and then put them back in. If it works it may not happen again. Typically this requires the camera be sent to the repair depot or replaced if your not lucky.
Aug 31, 2009 | Kodak Cameras
Hello, I have a Kodak EasyShare z740 camera, and a couple of days ago I was using it and it was fine. I tried to turn it back on today, and the light on the dial is orange, not green. The lens comes out,...
For this problem try the following:
* Try removing the memory and the battery
* Try using the camera w/o the memory card
* If problem still persist call the Tech Number
1800 235 6325 op 12 op 2
Hope this will help
Thanks
Byron
Aug 29, 2009 | Kodak EasyShare Z740 Digital Camera
E 18 problem
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Oct 02, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
The lens are out, and the camera won't turn on
Having taken apart a number of digital cameras I know they are fiendishly complicated inside. I can only suggest that you double check that the batteries are installed the correct way round and that you try again with new ones straight out of the packet.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills.
If they do not, please hold off on the rating and add a comment with more details so I can try to help you further. Cheers, D
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
My camera lens will not go back inside it is stuck,the camera will not work at all I tried to talk to someone at sanyo in april and did not get back ahold of me then I forgot about the camera now I would...
Try this: Power the camera on then gently push on the lens while hitting the power button again so that it will try to retract the lens. but be gentle as you could damage the camera worse.
if your interested in having it fixed for around 120 or more than dont try anything and just take it to a repair company.
if that doesnt reset the camera then you can try taking the batteries out for a couple day and then put some lithium batteries in it if it takes aa's that is. They have a little higher voltage than some batteries and while sometimes give it a little more push to get things going. Leaving the batteries out would let the camera forget its memory. If you had the camera stored without batteries then don't worry about trying to reset it as that would have already happened.
Let me know how that works or if you need anymore help,
Caleb
Jul 02, 2008 | Sanyo Cameras
Canon 20D err 99 and shutter going off continuously
its not the battery
its the exposure of the shutter speed of the camera
it might need to be set manually. set it to 2.8 or 4.5 speed
i had the same problem when i bought my sigma 20mm-80mm lens.
the lens wasnt talking to the camera properly, it didnt know what it was aying about exposure speed rate.
put the camera in AV mode and set the speed rate.
the lens might be compatible with your camera even though it is a canon, or it could be defective
return and replace
Apr 21, 2008 | Canon EOS 20Da Digital Camera
Lens doesn't retract when cover hits it. Only way to get lens to retract is to take out battery, put it back in, and then the lens slooooowly retracts, but will bounce back out if cover is closed...
The original problem was a camera with jammed lens mechanism or faulty lens motor. I think the camera had been replaced.
The following post is directed to new users following up on this thread, as the original problem had already been sorted:
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Sep 12, 2007 | Olympus Stylus 400 Digital Camera
Samsung S630 Digital Camera Logo
37 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
