Question about Panasonic Televison & Video
Problem setting up DVD home theatet sound system sc-pt460 with my vierra panasonic TV. The two appropriately connected with HDMI plus Optical cables. Mainly wish to use it improve TV sound. Have got it working but little and variable sound from rear speakers. Also when trying to adjust the sound settings do not get a visual display of the setting adjustments on my TV screen which the instruction book indicates should happen and is necessary for such adjustments. Have you to set it up with a SCART cable rather than HDMI connecting the TV and sound system? And if so do you keep the Optical cable in while setting up? Since all the equipment is the latest Panasonic I had hoped that seetting it up would be simpler. Have already been at it for 5 hours! Please help
To see the dvd sound menu option you must be on the correct input selection for your tv. ie. if its Scart, then AV1, or if HD then HDMI 1 etc. then you see the options. as for sound being variable, you can adjust the sound for each speaker in this mode. Main thing for having surround sound with normal TV is to turn on the sound enhancement mode. also, on your viera link on the tv remote, make sure sound its selected as home cinema. word of warning, leave dvd on D-In option, and when turning the TV off, use standby mode, which turns both systems off, ensuring the link does not break.
Posted on Oct 10, 2008
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Panasonic SC HT940 home theater doesnt work with my LCD TV
the HDMI cable sends dato TO the TV, it does not have enuf bandwidth to send both to and from, just TO.
Dec 27, 2009 | Panasonic SC-HT940 System
My surround sound will not work through the TV, only the DVD
If your tv and surround has an optical input/output.Then you can connect with an optical lead.This will then play the sound from whatever you are watching.You normaly select dig1 or input1 on the surround system.
Nov 12, 2009 | Panasonic Televison & Video
Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Jul 12, 2009 | Panasonic Televison & Video
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
How to connect Panasonic TV, DVD Recorder & Home Theater together
missing one connection connect stereo rca jacks behind tv labelled audio out then connect to any available input in home theater receiver i dont think you need the optic cable connected to anything
Jan 27, 2009 | Panasonic Home Theater System System
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Open Questions:
Televison & Video Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
