Question about Sony Ericsson K610i Cellular Phone
Problem of sim card
How i take out the sim card from phone
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 131 Answers
Slide the back battery clip down by using your thumb and make sure your fingers are not blocking the clip on the bottom. Then remove the battery and then you can take out your simcard.
b.r.
Posted on Aug 18, 2008
I cut my sim card for another phone but now I want to put into my alcatel onetouch, not sure how to put it in. can you help me?
First, read the owner's manual and see which type of SIM card your phone accepts or is configured to make use of for it to operate
Sim cards come in 3 different shapes
1. Normal Sim card
2. Micro Sim card (mid way)
3. Nano Sim card (smallest)
There are SIm card adapters so you can use Micro Sim card in Normal Sim card only phones
There are Sim card adapters so you can use Nano Sim cards in either Micro Sim card or Normal Sim card phones.
**Photos are less than 500kb size so can't upload for you to sight please.
This device uses a Micro SIM card. Insert SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card (flat-edge-first) into the slot, with the gold contacts facing down. Replace the battery while ensuring the gold contacts are aligned. Replace the back cover. Remove SIM CARD Turn the phone off. Remove the back cover using the notch located at the bottom edge of the phone. Lift the battery out. Slide the SIM card out of the slot.
Oct 08, 2017 | Alcatel Cell Phones
Tip
Phone displays "SIM card rejected" or "SIM card unaccepted".
The SIM (subscriber identity module) card is a small card inside your phone that establishes a network connection. The SIM card is provided by your operator or service provider. In most cases, they are the best source of assistance with SIM card problems. Your phone may display a SIM card error message if:
  • The SIM card is out of alignment. If the phone has recently been dropped, bumped, or opened, the SIM card may need adjusting. Follow the SIM card installation instructions in your user guide.
  • The PUK (Personal Unblocking Key) code is entered incorrectly multiple times. This can inactivate the SIM card. If inactivation appears to be permanent, contact your operator or service provider for a new SIM card.
  • You have recently changed service providers. In this case, either your SIM card or your phone may be configured for your previous operator and may require reconfiguring. It may also be that your phone is configured so that it cannot be used with a SIM card from a different operator or service provider. Please contact your current operator or service provider for assistance.
If none of the situations above apply and you continue to receive this error message, your SIM card may be damaged. Please contact your operator or service provider to have the SIM card tested and/or replaced. Or alternately, bring your phone to the nearest Nokia Care point for inspection
on Sep 12, 2010 | Cell Phones
STRAIGHT TALK PHONE
Troubleshooting - Sim Card - Straight Talk
https://www.straighttalk.com/wps/wcm/connect/StraightTalk/.../Sim+Card...
The "Enter PUK code" message means that the SIM card is blocked. ... Simply insertthe SIM card into the back of your phone or make sure that the SIM card ... on you may receive this message because your phone has not yet been Activated.
Products - Phones - Straight Talk
https://www.straighttalk.com/wps/wcm/connect/StraightTalk/.../Phone/
Straight Talk offers a variety of phone models to choose from. .... do support a SIM Card. However, if your iPhone is a 4 or 4S, DO NOT insert a SIM Card into it.
HI my straight talk phone is saying insert sim sos calls only ...
www.askmefast.com > ... > Phone
Jan 01, 2016 | Cell Phones
Sim card rejected to my nokia 2700classic cellular phone
Hi.Insert another sim card to your phone and try.if this doesn't solve , clean the sim card slot connector.Otherwise you need to contact a mobile technician.And if another sim card is working in your phone and your sim card shows Rejected to every phone,then the last solution is to change another sim card from the particular sim card provider.Good luck
Mar 02, 2012 | Nokia Classic 2700 Cell Phone
Even I inserted the sim card phone shows Insert sim card?How to solve it?
Well it is either a problem with the SIM card or the phone. First you should test out your SIM card.
Put the SIM in a friend's phone. If you put the SIM card in this other phone but it still says insert sim card, then it is the SIM that is no good. If the SIM works fine in the other phone, it would be the phone that is the problem.
May 07, 2011 | Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
When I switch On my phone it says "Sim card not valid". And its not taking the Sim Card. But without the sim card its perfect. My IMEI is 359849016183862. Please help me...
Hi, what might be the possible cause of the problem is either the Sim card your using on the phone or the Sim tray where the Sim card is inserted in the phone.
You can use the Sim card in another phone to be sure the Sim card is working properly.
After that, if the Sim card works,That means that Sim tray is damaged and will need to be replaced.
Have a nice day.
Sep 14, 2010 | Cell Phones
Samsung Geino, my sim is inserted but my phones keeps saying insert sim i carnt phone anyone blah blah help
Hi,when a phone keeps saying insert Sim card, is either the Sim card has problem or the Sim tray of the phone is bad and will need tobe replaced.
To confirm, Take the Sim card and insert it into another phone, If it still says insert Sim, that means the Sim card is bad, But if the Sim card works with another phone, That means the Sim tray of the phone is damaged.
Sim tray is located on the phone where you insert your Sim card in on the phone to make sure the Sim works with the phone.
Have a nice day.
Nokia 6500 slide sim card registration problemit normally says sim card registration failed immediately i on it
Hello
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
thank you for visiting fixya
Jul 24, 2010 | Nokia N70 Cellular Phone
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Sony Ericsson K610i Cellular Phone Logo
44 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
