Question about Xerox Office Equipment & Supplies
How do you get rid of the 'replace transfer belt' of a phaser 6110 MFP, event after it has been replaced?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
You need to reset the menu to default settings from front panel.
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
Please, send me the firmware for Xerox 6110 MFP for reset Image Unit;
firmware to have changed only very extreme case!!! no to reset image unit
Dec 07, 2010 | Xerox Phaser 6110 Laser Printer
Have a Phaser 6110 MFP. When I scan a page using the ADF I get 3 color lines running vertically down the image. If I don't use the ADF, the page scans without the lines. What could be causing this?
There are some small spots on the "seal" glass. It is the 3/4 inch wide strip under the scanner, not the main glass. Clean that strip well, I suggest taking some rubbing alcohol and just a regular piece of paper, crumpled up. Use that to clean that strip vigorously.
That will take care of it.
Jan 06, 2010 | Xerox Phaser 6110 Laser Printer
Phaser 6110 mfp , the display say that the scanner is locked , I don't have the manual with maiself
Check here.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=465,E=0000000001733349606,K=391,Sxi=10,Case=obj%284350%29
Oct 24, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
How can you reset the waste toner counter?
Hello there :
in the main menue of the printer there is a option that lets you reset it to zero but if this is a buisness printer you might have to have the company come and set it for you cause theire somtimes is a code that is entered to get to the main menue
Oct 23, 2009 | Xerox Phaser 6110 All-In-One Laser...
Scrunched paper
How old is the printer? It sounds like the rubber rollers have gotten hard and no longer can pull the paper through the vertical as quickly as the tray rollers do. I had a similar problem with a LaserJet4 printer and I had to obtain a repair kit (available online) and replace the old parts. Hope this helped.
May 28, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
XEROX PHASER 6110 MFP REPLACE TRANSFER BELT MESSAGE
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
May 18, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Noise after change color cartridges
is the toner cartridge and have a manufacturing defect or the toner cartridge scouer adaptable and look
Mar 07, 2009 | Xerox Phaser 6110 Laser Printer
Xerox phaser 6110 mfp
sir,
clean the LSU(Laser Sensing Unit) with a dry cloth.
Sep 25, 2008 | Xerox Phaser 6110MFP All-In-One Laser...
329 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
