Question about Whirlpool Duet GHW9150P Front Load Washer
WATER POOLS UP IN WASHER OVERNIGHT
I was told by my wife that the washer was not draining properly. using the tip from this website, I accessed the trap behind the panel, and emptied out a bunch of crud. I also removed the drain hose in back and it had a bunch of gunk in it that I cleaned out. It drains great now when the pump is going.
However, overnight, there seems to be water pooled up in the washer. She said it was drained fine when the clothes were removed last night, but there was water in there this morning.
Please Help?
  • 5,911 Answers
Siphoning, or a water inlet valve problem can cause this problem. Siphoning occurs when you have your drain hose inserted into the standpipe too far creating a vacuum. Not only does it cause problems with the washer's ability to maintain proper water levels, it can also cause back flow from the drain into the wash tub. Check your drain hose by lifting it up from the standpipe. You do not want the hose resting in the drain trap. You need an air gap to proper drainage. Do not seal the top of the standpipe and make sure the drain hose should be placed into the pipe about 4 to 6 inches only.
If you check the drain and it is fine, more than likely your cause is a leaky water inlet valve. The solenoids in the valve do go bad and can leak by, causing the washer to fill slowly during periods when it is not used. The valve is easily replaced by removing the washer top panel and shutting off the water supply. There a couple of mounting screws and dispenser hose to remove and thats about it.
HINT: A simple test to determine which one may be causing your problem would be to turn the water lines to the washer off for one night. If the problems goes away, you likely have a a water inlet problem. If the problem persists, you know you probably have a drain problem.
I hope this helps you. If you have questions, please let me know.
Posted on Aug 18, 2008
What does error F21 on my whirlpool duet sport front loader washer
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
Check your washer drain to make sure that it is draining properly.
Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Place a shallow pan on the floor beside the washer and then pull the drain hose out and place the end of it in the shallow pan to see if the washer will gravity drain. If it does, then excessive suds or a drain pump problem could be causing this failure. If the water does not drain or drains extremely slowly, you could have a clog in the drain system of the washer. Follow these steps to check for a clog in the large item filter of the pump:
Unplug the washer.
Remove the bottom front service panel as shown in the first image below.
Since the washer door is likely still locked, you can manually unlock it by carefully reaching up along the front panel and pulling down on the manual release tab of the door lock assembly until it clicks. You can then open the washer door.
Remove any clothes and then use a wet/dry shop vac to drain any water out of the washer.
Arrange shallow pans and/or towel in front of the large item filter shown in the second image below to catch residual water when you remove this filter.
Remove the large item filter as shown below. It is likely that you will find a clog in this area that is preventing your washer from draining.
If you do not find any clog or restriction in the large item filter and none of the other issues discussed above apply to your situation, then you could have a failed drain pump. If the pump is damaged and will not pump out water then it will need to be replaced.
These tips should help you resolve the F21 error code issue in your washer. If you need more help, resubmit your question with additional details.
Feb 21, 2015 | Whirlpool Washing Machines
Tip
Checking the Drain Pump on a Whirlpool Cabrio
This advice explains step-by-step how to inspect for obstructions in the drain pump of a Whirlpool Cabrio. This model washer actually has TWO pumps. One is the drain pump, one is a recirc pump. The easiest way to access the pumps on a Cabrio is to tip the washer back and work from the bottom. There is a rear panel access you can remove for added access, but it limits your ability to get to the mounting bolts. These washers are heavy, however, and removing any excess water will help minimize weight and the potential mess you are going to have to mop up when you remove the drain line(s) from the pump. The easiest way to do this is to use a wet/dry shop vac and pull a vacuum on the drain line. You may have to repeat this procedure several times as the Cabrio has an extra large capacity drum and tends to hold more residual water than most other washer models.
NOTE: Residual water in the wash tub, drain lines and pumps is NORMAL.
With the residual water removed, carfeully tip the washer back against the wall. Place a towel between the washer and wall to avoid marring of the washer or your wall.
NOTE: A second person is recommended to hold the washer in place so it doesn't not fall. When working alone, I have used blocks of wood (such as a 2x8 standing on edge) to block the washer up as a safety precaution.
As you are viewing the washer from the front, the drain pump will be on your RIGHT hand side. The recirc pump is on the left. Either pump comes out easily by following these steps:
1. Make sure the washer is UNPLUGGED before you begin.
2. Carefully disconnect the electrical connection.
3. Remove the mounting bolts that hold the pump in place.
4. Remove the inlet and drain hose(s) from the pump.
With the pump free, you can easily access the impeller area and retrieve anything that may be caught. Drill bits and screws are commnly found as they will pass through the small holes in the wash tub spin basket.
I would begin with the DRAIN pump, first. It tends to be the catch-all for everything. If the drain pump is clear, inspect the recirc pump as well.
To reinstall, follow the steps I have provided in reverse order. NOTE: Some people prefer to remove the the drain hose before unbolting the pump. Choose whatever method you prefer.
If the pump impeller is damaged, the pump will need to be replaced.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need.
I hope this information is helpful.
on Feb 18, 2010 | Washing Machines
Water pooling in washer when not is use
if you can get to the valve, disconnect the molex to the solenoid and if the water stops you have a control problem if it does not then the valve is bad
Feb 19, 2013 | Maytag Neptune Washer
Washer sounds like jet engine was told it is the drain pump how hard is it to replace
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
I have a Kenmore frontload washer model number 48112. I believe the drain is clogged. How do remove the front panel to access the drain pump?
First, unplug the washer and turn off the water. Get a small block of wood (about 6 inches high). Pull washer away from wall. Tilt back and place wood block under washer. This will allow you to access the 3 bolts on the bottom of the kick plate. Using a 1/4" socket, remove the bolts and set aside. Pull kick plate down. The drain pump is conveniently located in the front on the right hand side. Before proceeding, grab a garbage bag with no holes in it. You will use this to catch the water that will come out when you unscrew the filter. Place garbage bag under filter housing. Make sure to use one hand to keep the bag in contact with the filter housing (or ask your wife, kid, neighbor, etc to help with this) while unscrewing the filter in a counter clockwise direction. It will be difficult to turn due to the o-ring. Be patient. Turn it slowly. Water will start to come out as the filter is loosened. You may want to pause at this point and let the water drain. BEWARE! The will most likely have an offensive odor to it. Once all the water has drained, you can finish unscrewing filter and find your reward. I found a key, necklace, coins (mostly dimes), drill bit, nylons and lint. Be sure to clean the filter and housing with a bleach solution or vinegar solution before replacing filter. When replacing filter, be sure that it is tightened all the way down. If not properly tightened, the washer may leak when in use. Put kick plate back on and secure with the 3 bolts. Tilt back and remove wood block. Plug washer back in and turn on water. I would recommend running a clean cycle before using.
Aug 06, 2011 | Kenmore HE2 Plus Front Load Washer
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I fixed a similar problem, so I hope this info helps!!!
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
http://media.fotki.com/1_p,wktwwdgrkbbfrdgxgtqsskgwtqkq,vi/kstdgfskbxktqtggsqb/1/1303472/5961857/image64920img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 21, 2009 | Kenmore 44042 Front Load Washer
Leak. My wife noticed water leaking out bottom of washer
Try cleaning the drain plug. I did this in about 5 minutes and was amazed at how much debris was clogging up the drain. Mine was accessible by removing two screws at the bottom of washer and removing panel. Drain plug was right there and easy to unscrew. Be sure to have a cookie sheet or other pan to catch the water that will flow out. Once that drain is clear, thumping should stop because water can flow down the drain easily.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
142 people viewed this question
Dan Webster
Dan Webster
Sal De
