Question about EliteGroup P4VMM2 Motherboard
Mother board what is the problem after I installed my P4 1.8Ghz Processor to a mother board m925 ver 7.3. it will beep around 5 times when I restart. but when it cools down for 2 min. it will start. MTS
  • Mario Soriano Aug 20, 2008
    I've tried to reconnect all the connection still same problem I encountered. the processor came from a green board socket 487 and I transfered it to a red board 487 the computer started in normal but the problem when I restart it, it beeps and I will wait for a few minutes so it will start again normally. what is the problem
    I've disconect everything except mem. and processor but still same problem
  • 3,051 Answers
Have u checked the power supply and all of its connections and the system board fan to make sure they are operatring correctly and also is the beep code a straight 5 beeps or is sthere any thing else kplease let me know so i can try to give you some more help
Posted on Aug 20, 2008
  • 2 more comments
  • Michael Thomas
    Michael Thomas Aug 20, 2008
    ok try to disconnect everything from the board meaning the harddriver and the cdrom and the a drive and try to boot the computer and see if the thing still beeps if so there is may be a compatibility issue there please continue to let me know ok i can help more if needed
  • Michael Thomas
    ok you can try to remove the memory sticks 1 at a time and reboot and see what happnes if this doesnot help than i think that the processor is causing the probnlem
  • Michael Thomas
    Michael Thomas Aug 21, 2008
    also if you remove the processor from the computer and check the white heat shrink under it and make sure it is there
  • Mario Soriano Aug 16, 2016
    thanks for the tip
P 4M800PRO-M V1.0A ECS mother board does not beep ,it gives click sound . but some time it start and run good condition .and next restart ,mother broad doesn't start
Sounds like that board is on its way out. Had a good run too!
I'd seek out a complete system upgrade.
Small things you could try is reseating the RAM and testing it with a new power supply.
Hope this helps!
Sep 16, 2014 | Computers & Internet
Dell studio 1558 wont start up beeps 7 times
Your beep codes indicate a processor failure, did you purchase a new processor with the MB or did you use the old one?
Nov 23, 2012 | Dell Studio 1558 Notebook
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at: http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
I want drivers for gf7050v-m7 se mother board for windows 7
download windows vista driver for your support driver windows 7
biostar mother board GF7050V-M7 Ver. 6.x
biostar mother board GF7050V-M7 SE Ver. 6.x
Nvidia support driver Click here
or you can select option 2 on the page that appears to automatically detect product nvdia
gud luck
Oct 19, 2010 | Biostar GF7050V-M7 nVIDIA GeFORCE 7050...
Hi. My motherboard (MB) M925 V7.3 gives 3 long
Here's everything you ever wanted to know about Power On Self Test codes:
<a href="http://www.computerhope.com/beep.htm">http://www.computerhope.com/beep.htm</a>
Your three long beeps indicate the absence of a peripheral device known as a keyboard or mouse or other input means as follows:
Three Long Beeps Keyboard / Keyboard card error. CH000304
Mar 26, 2009 | PC Chips (M925G) Motherboard
Hoe to install the mother board
first install the processor. then the mother board places in the casing. screw it up. then add ram, hdd, dvd rom. at last connected the power cable, restart cable, hdd light, power light.
Jan 20, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Gigabyte mother board ga-6bx7+
You might have damaged the CPU/ motherboard during the process of overclocking.
Check your CPU on other compatible mobo.
Check your mobo documentation properly & set the jumpers rightly. If that doesn't help, you will have to replace the mobo.
Jul 01, 2008 | Gigabyte GA-6BX7 Motherboard
EliteGroup P4VMM2 Motherboard Logo
206 people viewed this question
Top EliteGroup Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
David
David
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
