Question about Toshiba Satellite A135-S2276 Notebook
Need a password...
Good morning!
Do you know what the default BIOS password is for a Toshiba Satellite A135-S2276 laptop?
    Scholar:
  • 94 Answers
Found these instructions on another website...
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Hope this helps
Regards
Posted on Aug 18, 2008
Toshiba satellite A135-S2276 cannot get pass bios password and none was set
Try removing internal battery this is ussually a small battery on the motherboard which keeps in its memory date and time ,hard drive details ,passwords etc.
Some batteries are easily removeable some have to be desoldered so it losses whats in its memory. The laptop is then switched on to see if the password is gone.. Then battery put back. Some laptops have to be taken to manufacturer to take password off..Good luck
Jan 28, 2011 | Toshiba Satellite A135-S2276 Notebook
How to reset cmoss password in toshiba satelite A135-S2276 service manual
You can try some BIOS hacks, just google them. Or you can try and take your laptop apart (use the manual), locate the BIOS battery, take it out and leave it for 5-10 minutes and the password should be reset either to default or nothing.
Jan 12, 2011 | Toshiba Satellite A135-S2276 Notebook
How to removed a toshiba satellite a135-s2276 password from bios
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Default phoenixbios pasword
If you've lost the bios password, you'll probably have to 'flash' the bios. If you feel comfortable enough, you can dismantle the laptop and remove the motherboard battery for several minutes, then replace it and reassemble the system, see if the password has been cleared. (Note: The motherboard battery is NOT the laptop battery; you have to remove both!)
Feb 13, 2009 | Toshiba Satellite A135-S2276 Notebook
Forgot the bios password
WHEN YOU FORGET YOUR BIOS PASSWORD YOU HAVE TO FIND THE BIOS BATTERY ON THE MOTHERBOARD ANDREMOVE ONE LEAD TO THE BATTERY WAITE 10 OR 15 MINUTES
THEN REPLACE IT AND YOU ARE GOOD TO GO
Dec 08, 2008 | Toshiba Satellite A135-S2276 Notebook
Default bios password toshiba satellite a135-s2276
the best thing is to do the system recovery process ..
Aug 09, 2008 | Toshiba Satellite A135-S2276 Notebook
Did you get this from another person or business?
Either way there's a way to get rid of it.
Let me know
comier957
Aug 08, 2008 | Toshiba Satellite A135-S4527 Notebook
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
Jun 03, 2008 | Toshiba Satellite A135 Notebook
what you need to do is pull both the laptop battery as well as the cmos battery. in some instances, the battery can be pulled, but on other models, i have seen the battery as an actual physical part on the motherboard or somewhere where it is not easily accessible, in which case you need to clear the cmos by using a jumper on the motherboard, since it is a laptop, they are all different. you may need to see if you can locate a copy of the motherboards schematics and go from there.
May 29, 2008 | Toshiba Satellite A135-S2386 Notebook
Reset Toshiba Labtop A135-S2276 Bios Password
see the below post for a possible solution http://www.fixya.com/support/t187128-toshiba_m105_s3004_bios_password
Aug 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
186 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
