Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
It does not ****
Hello experts,
I have problem with my windtunnel vacuum, first it full then replace the new bag. The problem i have now it does not ****. The motor work okay and full indicator show full.
    Problem Solver:
  • 6 Answers
Greetings from,
It sounds like you have a clog in the vacuum cleaner somewhere. What you can do is remove the hose from the back of the vacuum cleaner and see if the changes the bag full indicator, and pay attention to the sound of the motor. If the motor starts making a high pitch sound as soon as your install the hose, this means that there is a clog somewhere in the hose.
If you can give me your model number, I can send you a parts schematic to your vacuum cleaner.
Chris Jones
Posted on Aug 18, 2008
Hoover windtunnel
Hello--How about the Flat belt? That would be my next step...then, if it's still not turning, perhaps the beater/agitator bar's bearings are the culprit...calling for a new beater bar /agitator.
Hope this helps--
Aug 28, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Why is my hoover windtunnel vacuum cleaner shutting off?
Hi there! Sounds like the thermal protector is being activated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow the steps below to prevent the unit from shutting off.
1. Remove the hose completely.
2. Use a broom stick to gently loosen and clear hose of clogs.
3. Remove the bottom plate and brush-roll.
4. Use a wooden spoon or something similar to break up and remove any clogs from lower hose.
5. Check the primary filter behind the side grille. If it is dirty you may rinse it under running water and allow 24 hours to air dry outside the vacuum.
6. Remove the bag door. Clean the primary filter located on the vacuum under the bag. Rinse with water and allow 24 hours to air dry outside the vacuum. The primary and secondary filters should be replaced at least once a year.
7. Check that the bag is not full. If it is, replace the bag.
The vacuum will turn back on when it cools off. This can take up to an hour. Hope this was helpful!
Jul 08, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
How replace hoover windtunnel self actuator arm
Hello! We recommend taking your vacuum in to a Hoover authorized service center to have the self actuator arm repaired or replaced. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Jul 04, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Mach 2.1 bag?
Hello! The U6437900 takes Genuine Hoover Type Y bags. Follow the link to place an order for replacement.
Type Allergen Bag 3 pack
Jun 25, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
I need a new bag for the Hoover 3.8 Model # U5465-900 which bag is it ?
Hoover Genuine Hoover Type Y Allergen Filtration Vacuum Bags, Fits Hoover Windtunnel and Hoover Tempo Bags Hoover 4010100Y
Feb 17, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Does not move on its own. put in new back and the bag indicator says it is full
The belt that drives the self propelling feature is probably worn. Your model has two belts and they should be replaced yearly to ensure optimum performance. You can get the belts you need here:
Hoover Windtunnel Replacement Belts
Nov 02, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel has no suction
May 03, 2009 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
147 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
