Question about Brother HL 5250DN Laser Printer
Paper rolls up
When I print with my new 5250DN the paper rolls up and blocks new pages from being printed
  • teek74 Aug 28, 2008
    Thanks buddy!
  • 138 Answers
You have a humidity issue with your paper. Buy or open a fresh **** (sealed) and try printing again. If your paper is stored in a cool place move it to a warmer area. Paper tends to pick up moister over time, especially when cold and will curl when printing. The paper is actually steaming when it hits the fusing (heating) section in the back of the printer. The curl is because one side of the page is drying faster than the other.
If you have a case of paper and open a fresh **** with similar results, buy a new **** and try again. When selecting your paper buy good reliable paper. I recommend "HP Office" branded or better. I say stay with HP Brand paper as it's manufactured to a tight quality standard than most and is a "known good" paper. STAY AWAY FROM STORE BRANDS as they go out on low-cost bids and the quality varies widely on whoever got the contract this time.
As a more positive note, If you use a good paper in your printer, your drum cartridge (expensive) and toner cartridge (not cheap) will actually last much longer. You'll save more (much more) in the long run.
Hope that helps you.
"A little free help from a tech fixing 10 to 15 printers a day for 13.5 years."
Posted on Aug 26, 2008
Stop Ejection of printing paper roll after printing in dot matrix printer
I assume you are printing on roll paper, but printer acts like it is printing on cut sheet paper. When finish the page, it ejects it, but it is not a page, it is a roll and the paper keeps unrolling, right? There have to be a lever that swithes between cut sheet paper and roll paper. Turn it to the oposite direction and the problem should be fixed.
May 18, 2015 | Matrix Office Equipment & Supplies
Duplex feed not working
Check the C6200 Device Settings in the properties and make sure that the Duplex Unit is installed.
original?v=mpbl-1&px=-1
Dec 09, 2013 | Brother HL 5250DN Laser Printer
My Brother 5250DN is not pulling paper through. What could it be?
do a test print... see you manual. You hold a button for 3 seonds and it'll print a test page. If that works you should be OK. Make sure that your paper tray is NOT over loaded. Maybe try less paper. Try the manual feed using one sheet of paper
Oct 27, 2009 | Brother HL 5250DN Laser Printer
I have a brother hl-5250dn with an extra tray for legal size paper. I have a problem printing loan documents sent via swiftview or elynx. I can only print on letter pages or legal pages but not both and...
Sounds like your secratery's printer is set to ignore paper mismatch errors. It depends on the setting you have in your driver. Can you set your driver on your printer to ignore paper mismatch errors. If not when your printer errors, just try hitting the go button and it should print the document any way.
Sep 07, 2009 | Brother HL 5250DN Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Only print part of the page.
Check your print settings.How many copy you are selected for print.
Nov 15, 2008 | Brother HL 5250DN Laser Printer
HP 1320 duplex printing paper jam
Managed to solve this myself: I disassembled the printer and noticed there was a paper jammed in the duplex tray. Rolls were all ok, but the paper blocked the use of the duplex pathway. For disassembly help check the HP 1320 service manual, which you can find on the net as a PDF.
Jul 14, 2008 | HP LaserJet 1320 Printer
Feeder wheels are spinning backwards
I see that you have mechanicals problem the doublex maybe faulty
i need from you to tray clean the printer all printer roller and tray to disable the doublex future from the driver try to print and send to me feed pack
Dec 05, 2007 | Brother HL 5250DN Laser Printer
Paper gets stuck in printer
Hi, I work on these alot and see the problem quite frequently. It can usually be fixed by 1. either replacing the drum and toner which will eliminate alot of guess work, and if that doesn't fix it then 2 you have a bad fixing unit (AKA fuser). The folded paper makes me think that it's most likey a fuser problem but you can check by opening the rear door and looking for two rollers that are about as thick as two fingers and see if they roll during a test print. Sometimes the gear on the fuser gets broken and while the printer thinks that everything is working okay, it doesn't have a way of sensing the fuser actually rolling. Just as an FYI (and I know this isn't good news) but usually a fuser/fixing unit runs about the same price as the printer itself. So if your printer is on the older side you might want to consider a new one. Good luck.
Aug 28, 2007 | Brother HL 5250DN Laser Printer
Brother HL 5250DN Laser Printer Logo
97 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
