Question about HP Compaq nx9020 Notebook
Sound not working - HP Compaq nx9020 Notebook
    Sergeant:
  • 228 Answers
Check Device Manager to for any "unknown devices", your audio device driver might be one of those. Unknown devices usually appears if the device driver (ex. audio driver) is not installed. You can also find an "exclamation point" under "Sound, video and game controllers" if there is conflict on the driver causing no audio to be heard from the unit.
To resolve the issue, you can either use the Drivers installation disc which came with the computer or Right-click on the "unknown device" and select "Update driver" button.
For pc users who doesnt know how to check device manager, follow below steps:
Windows XP
- Start > Run > type devmgmt.msc on the box then hit enter key. or you can also
- Start > Right-click My Computer > Properties > Hardware tab > Device Manager
Windows Vista and 7
- Start > type devmgmt.msc on the search box then hit enter key or
- Start > Right-click Computer > System Properties > Device Manager (link at the left pane)
Hope this helps.
Posted on Jun 06, 2011
SOURCE:
Why would tv sound work fine but while using roku 2 the sound suddenly stopped working?
If the picture is OK then check your sound cables, red and white if analog, or swap out the HDMI cable with one that you know works.
Also, on the SETTINGS screen make sure your audio is set to stereo not surround sound.
Dec 27, 2014 | Roku 2 XS
Speakers are not working in dell inspiron 6000
Please connect an external speaker or headphones and check if you get sound. If sound works then the issue is with the onboard speakers in the laptop.
If sound does not work with the external speakers or headphones then the issue could be with the sound card driver or settings.
Dec 25, 2010 | Dell Computers & Internet
The sound isn't working on my pc. I have checked speakers on a different pc and they work fine. Have you any idea what the problem could be?
Have you checked the sound driver? Does the sound work with headphones?
If the sound driver is correct and working there will be, when checking the sound mixer, moveable virtual slider controls.
If it works on headphones, the headphone socket may be faulty.
The likelyhood of no sound due to a power problem is not very high.
Nov 17, 2010 | E-Machines (T2824) PC Desktop
Sound card stopped working
1st you disable the onboard sound card in BIOS level, then install/update the sound driver for Maddog Prowler 4.1 DSP soud card will solve your problem.
Dec 08, 2009 | Mad Dog Multimedia Prowler 4.1 DSP Sound...
I have a Dell Dimension 4600, will a PCI Express sound card work in place of the original Sound Blaster 5.1 sound card
Well, the short answer to your question is "No, it won't work". The Dell Dimension 4600 does not have any PCI Express slots in it, therefore you can't install it, and therefore it won't work. But, if you installed a PCI sound card, it would work. The BIOS would recognize the add-on sound card, disable the onboard sound, and your sound will start going through the expansion card instead. Hope this helps.
Jul 18, 2009 | Dell (8H390) Sound Card
New Sound Card is not working.
Ted, the first thing you should do is go into your computer's BIOS and disable the built-in sound card. Once you do that, go back to your device manager and if the onboard sound card still appears there remove or disable it. Then reboot and your new sound card should be recognized and you can install drivers and begin using it.
Apr 25, 2009 | Computers & Internet
Toshiba satellite L10 117 sound problem
The internal sound does not work but external sound works.Please help. contact me ady_service_pc@yahoo.com
Apr 30, 2008 | Audio Players & Recorders
Sound
the sound card is to be attached to the isa slot, if working should receive its resource and work, carefully attach the sound card to the isa slot, if working sound card it will be read if not it won't then put a working sound card.
UZOWUANYA
e-mail uzowuanya@yahoo.ca
Feb 15, 2008 | AOpen AX45-V (91.88I10.004) Motherboard
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Dec 24, 2007 | Creative Labs Audigy Gamer Sound Card
HP Compaq nx9020 Notebook Logo
162 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
