Question about GE Energy Star WCVH6260F Front Load Washer
Torn Gasket So how do you replace the gasket?
  • Anonymous Sep 27, 2008
    The same problem, this washer at least is 1 1/2 year old. And this part is really expensive!!! $100 if you find it cheap! Almost new washer and now I have to go to the laundomat! Why is this happening too much with almost all those washers and models. Do not recomend this washer to anybody. My mom has her old washer for more than 20 years and never has been repaired. I think I'm going back to the old style!
  • Anonymous Nov 21, 2008
    Do I have to remove the front to remove the inner clip? I can't get anything to reach at that angle.
I tried doing it with out removing the front panel and it was a nightmare putting it back on. The trick is having a screw driver that reaches and fits in that little area. Also, I had to use clamps to hold the gasket in place while putting the wire clamp back on. If I had to do it all over again I would have hired someone. I am pretty handy, but my time is sometimes worth more than doing it myself. This washer is a peice of ****. Everytime I wash a load it sounds like king kong is beating on the laundry room door. The damn thing is never in balance.
Posted on Dec 14, 2008
  • 725 Answers
1) remove spring clip. ( at the bottom of the gasket use a screw driver to pry spring off)
2) push gasket into tub
3) remove inter clip ( loosen screw )
4)remove gasket
5) start at the top push gasket on out tub
6) replace inter clip
7)replace outer clip
Posted on Nov 17, 2008
4 Suggested Answers
SOURCE:
SOURCE: torn gasket on a front load ge washer
Not too hard or technical. I followed John in Erie's instructions:
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
I bought my part at Appliance Zone. From what I paid and how long it took to get to me, I should have just bought it locally for a little more and had it delivered a lot sooner. Replacement took an hour and a half.
Posted on Dec 21, 2008
dniro592006
  • 121 Answers
SOURCE: the rubber door gasket is torn, how to replace,
Get the model number off the washer
and go to appliance store who service or Sears
Posted on Jun 11, 2009
SOURCE: our gasket tore. How do you replace the gasket?
Its actually pretty easy.
1, Remove the top of the washer
2. Remove the screws behind the front panel with the knobs and buttons. set the whole assembly on top out of the way
3. remove the door of the hinge. there are 4 screws
4. remove the concrete weight
5. remove the back band folding gasket. It has a bolt.
6. remove the front band, its just under spring tension
6. replace gasket and install back band first.
7. work your way backwards from here.
Good luck
Scott
Posted on Aug 21, 2009
HI what can i use to bond my refrigerator door ruber which is torn
Replace the gasket. The magnet used to seal the gasket to the refrigerator or freezer frame pulls on the gasket every time you open the door.
Jun 22, 2014 | Maytag Refrigerators
Felt front gasket torn
Your local appliance parts store will have a felt gasket kit with all you need to repair it. If you aren't handy, you may want to call a technician.
Mar 21, 2014 | General Electric Dryers
White smoke from engine
Gasket is torn or cover is loose. Replace gasket or make sure cover is tightened.
Jun 29, 2013 | Vehicle Parts & Accessories
Torn piston gasket sky687 hammer drill / jackhammer
Can you substitute a liquid sealant or permatex compound?
Feb 14, 2013 | Drills
Torn door gasket / collar
It requires technical expertise and speccial tools. Part isn't expensive, labor may be depending upon where you live
May 05, 2010 | LG WD-14124RD Front Load Washer / Dryer
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Our gasket tore. How do you replace the gasket?
Good luck
Scott
Jun 14, 2009 | GE WBVH6240F Front Load Washer
I was cheated. . . need advice
You didn't buy this from a dealer did you? Try (repairpal.com) for estimate for repairs that zero's in on your area rates via postal code for closer estimate. You just enter info on vehicle & pick repair to be done.
Mar 27, 2009 | 1992 Honda Accord
My front loading Kenmore H2 has a torn gasket.
You will have to take the door apart to get the gasket mounted properly. Although not required, a second pair of hands really helps.
Mar 19, 2009 | Kenmore HE2 Plus Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
85 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
