Question about HP Office Equipment & Supplies
The machine will not send faxs nor receive them. it will make copies and the time and date works.
    Scholar:
  • 159 Answers
Betty, make sure that you can hear the on line signal when you lift the handset. If you can, try sending a fax using the manual method. If you can't hear a signal, unplug the machine from the telephone line and plug another telephone in it's place. If you still can't hear the line, there is a problem that needs the telephone line repaired. If you can hear the line, then either the line cord is not plugged into the correct jack on the machine, or there is something wrong with the machine itself or the line cord even.
Posted on Aug 19, 2008
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
Panasonic UF-490 Fax machine is sending more than one fax
You might have a job stuck in memory. Message window should say 00%. Try this press Function key press 7 key press monitor key slowly 4 times press * key press 6 key scroll down to ALL JOB CLEAR press SET wait for reboot Good Luck
Jun 05, 2009 | Panasonic Panafax UF-490 Plain Paper Laser...
Brotherintellifax4100...will not copy, send or receive fax
This might work: Press Menu, Mode, 0 to enter the Maintenance Mode. Then touch 91 to clear most of the machine's memory. (But not your phone numbers & stuff.)
More likely, that won't work, because your keyboard is messed up. These machines won't allow you to press a key when another is still down. Is one key sitting lower than the others? Or maybe water has been spilled in the keyboard? The keyboard itself might be bad. I've had to replace one only once, but it happens.
May 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Time date stamp on fax machine
The time it was sent, if they have the time set correctly on the sending fax machine
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Fax is received is very dark and almost unreadable
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Jan 05, 2009 | Sharp Office Equipment & Supplies
I have the stupidest question. i have a brother fax 560 plain paper fax. Do i load paper face up or down to send a fax? THank you!
just check there wilkl bi mention face up or down .if not mention no problem just make a copy by putting face up and one copy by putting it face down.one time u will receive white copy and one time u will receive print on paper .when u will receive print check this is face up or down .after confirm just send fax
Dec 16, 2008 | Brother IntelliFAX 560 Plain Paper Fax
BROTHER FAX MACHINE 2800
Your Brother machine#s Sleep Mode function reduces power consumption while the machine is idle. You can adjust how long your Brother machine is idle (between 00 and 99 minutes) before Sleep Mode is initiated. Please note that the default setting is 00 minutes, and the timer automatically resets itself after the Brother machine receives a fax,receives data from your PC, or makes a copy. To adjust your Brother machine#s Sleep Mode setting, please follow these steps:
1. Press MENU/SET, 1 (General Setup), 7 (Sleep Mode).
2. Use the dial pad to enter the amount of time the fax machine is idle before Sleep Mode is initiated (00 to 99 minutes).
3. Press the MENU/SET key to confirm your choice.
4. Press the STOP/EXIT key to exit the menu.
NOTE: If you frequently print, copy, or fax, set the idle time long
enough to insure that you will not always have to wait for the Brother machine to warm up.
Dec 02, 2008 | Brother IntelliFAX 2800 Laser Fax
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
52 people viewed this question
Seeker5211
Seeker5211
