Sony Playstation 3 (PS3) Console Logo
Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PS3 shows a blank screen when I use the RCA jacks but works well when watching DVD movies when using a HDMI cable. When using the HDMI cable the sound is distorted whe I insert a game disk
Anonymous
Level 2:
New Friend:
  • Expert 51 Answers
  • Posted on Jun 07, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
51
Questions
0
Helped
24032
Points
135
Well heres the problem when you set your ps3 to be on 1080p using a hdmi cable the rca jacks wont work. to reset it power down the console. Then hold your finger on the power button you will hear it beep twice i believe rca jacks should be working now you will have to do that everytime unless you change it with hdmi cable plugged in to where you can see.
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
How to connect dvd to tv.
Good day!!!!
Please try this procedure on how to connect your DVD player to your TV..
Follow this instructions:
1. Check the back of your DVD player. It will have up to three different types of outlet connections enabling it to be linked to the TV. The most ideal is an HDMI connection, which is a thin rectangular outlet marked "HDMI." It provides the highest quality signal to your flat panel TV. If your DVD player doesn't have an HDMI outlet, you can also use a standard RCA outlet. This consists of three round cable jacks labeled with a color coding. The yellow jack is for the video signal while the red and white jacks are for audio signals. Some DVD players may have an S-video outlet as well. It will be a circular jack with a number of holes. While not as effective as the HDMI jack, it provides a clearer picture than the RCA cables.
  • 2. Look at the back of your flat panel TV for a series of "In" jacks corresponding to your DVD player. There may be a number of them under different labels (Input 1, Input 2, HDMI 1, HDMI 2 and Component Video are common). All of them work, however, and all can carry the DVD signal into your TV. Simply select an "In" jack that matches the DVD outlet you have selected and note the precise label.
  • 3. Connect the "In" jack from the TV to the corresponding outlet on the DVD player, using the proper cable (RCA, HDMI or S-Video).
  • 4. Turn on the TV and press the input button to select the jack connected to the DVD player. (The exact label for the input button will vary by model. Some will say "Input," while others will say "TV/Video" or "Signal.") A menu should pop up onscreen giving you a list of jacks in the rear of the set. Select the jack connected to the DVD player. The name of the player brand should appear on your screen.
  • 5. Place a DVD in the player and watch as normal.
  • I hope this procedure will be helpful...Thanks for using fixya..
    2helpful
    Hi. I have recently purhased an Acoustic Solutions DVDRW300 DVD Recorder. I have no instruction manual and have no idea how to set it up or work it!! Please help as im totally useless!!
    Hello!
    I am assuming that you want to INPUT your TV/Cable Box to your DVDRW, and have the DVDRW then be able to OUTPUT to the TV.
    Here's what you need to do:
    1. Locate the OUTPUTS of your TV/Cable box at the back of your set. There should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI . Make sure that they are OUTPUTS. It'll probably say TV-out or just out.
    2. Locate the INPUTS of your DVDRW. Similarly, it should either be the RCA jacks (Yellow/White/Red), S-Video, VGA, DVI or HDMI. Ensure that they are INPUTS.
    3. Match up the outputs to the inputs. Now, I have listed the OUTPUT/INPUTS going from lowest quality to highest quality. So let's say your TV has RCA, S-Video and HDMI outputs, and your DVDRW has only RCA and S-Video. HDMI is ruled out, unless you get a converter (which is pretty pricey). Choose which one, and buy/use the right cables.
    4. Here are the connections for each type of OUT/IN. (TV/Cable >>>>> DVDRW)
    • RCA (Yellow/White/Red) >>>>> RCA (Yellow/White/Red)
    • S-Video + RCA (White/Red) >>>>> S-Video + RCA (White/Red)
    • VGA + RCA (White/Red) >>>>> VGA + RCA (White/Red)
    • DVI + RCA (White/Red) >>>>> DVI+ RCA (White/Red)
    • HDMI >>>>> HDMI
    5. Connecting the DVDRW back to the TV. So now, you can record whatever is playing live on your TV. But you also want to play things from your DVDRW on your TV. Check the OUTPUTS of the DVDRW. It should have either the same jacks as the INPUTS. Check the INPUTS of the TV.
    6. Follow Step 4, and 5. Note that for connections, you are going from the OUT of the DVDRW to one of the INs of the TV. Keep track of what INPUT on the TV you are connecting to.
    Voila! Let's test it, though. Now, turn your TV and DVDRW on. Put in a DVD (a movie perhaps) in your DVDRW. On your TV, switch the channel to the INPUT channel you used. You should see your movie. If not, try another INPUT on your TV.
    If it's fine, then let's try recording a TV show. Switch the channel on your TV to whatever you want to watch, say Cartoon Network. Put in a blank DVD in your player/recorder. Hit record on the player. Let it record about 2-3 minutes, and stop recording.
    Switch the TV back to the INPUT which works, and hit play on the DVDRW. You should see what you recorded.
    Hope this helps!
    My ps3 wont work with my hd/mi cable, i get a blank screen, but it does work with the rca jacks?
    What you need to do is connect it from both the red/white/yellow cable and your HDMI. Go to your video input on your TV to where you can see the display. Go to settings - Display settings, and switch your input display from composite to HDMI. Your screen will go blank. Once blank, turn your TV to your HDMI input and when you see the picture, save settings and completely unplug the composite cable. You should be good to go.
    If this helps, please give me a 4thumbs up!
    Respectfully,
    Don
    PS3 Screen is blank
    No i think your ps3 froze or your settings r 4 hmdi and not snail cables next time reset your tv sometimes the hdmi freezes
    I've just purchased an InFocus x10 and i'm having problems playing my ps3 on it. Playing movies through my dvd player is fine but when i switch it over to the ps3, it is having problems detecting the...
    I have the same problem. I actually get the initial language choice screen showing up on my X10 and then once I select a language, the PS3 says that it detects an HDMI device and do I want to get sound and video through HDMI. I say yes, and screen goes blank. Saying no, screen also goes blank.... Any solutions to get past this screen?
    DVI to HDMI problem please help
    So have you found a solution to connecting your PS3 through the HDMI-to-DVI cable? I am also getting the "Invalid Mode".
    Progressive scan
    Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
    Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
    For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
    Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
    If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
    The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
    Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
    123helpful
    9answers
    Ps3 wont show up on tv
    Hey i just posted i have the same problem as you do but then I checked the SONY PS3 website and it solved my problem. Try resetting your video output. I'll paste what it says on the PS3 website but if that doesn't solve your problem go to the website. They have a bunch of troubleshooting solutions for this problem...
    If while manually changing the Video Output Settings, the screen remains blank for more than 30 seconds, you may need to perform the following steps to reset the Video Output Settings.
    1. Make sure the Component AV Cable is connected to the [AV MULTI-OUT] port on the back of the PLAYSTATION 3 system.
    2. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
    3. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
    4. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
    Top Sony Video Game Consoles & Games Experts
    Grand Canyon Tech
    Grand Canyon Tech
    Jose Ramirez
    Alexander
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
