Question about Fisher and Paykel GWL11 Top Load Washer
Error 37 How do I get to the pump? LeRoy
  • leroyblanks Aug 19, 2008
    Thank you very much for the help. I was able to get to the pump and remove it.
    LeRoy
  • 125 Answers
Pull machine away from the wall and tip back, make sure you get as mush water out of the tub as you can. a shop vac works the best. the pump is on the right front of the machine, it has a fan blade on the bottom of it, you can also tip the machine back and try to spin the pump to get it to pump out the water, also check to see if anything is wrapped around the fan blade, ( have seen socks and dryer sheets stall the pump). no tools required, there is a tab that you push while you turn the pump. hope this helps
Posted on Aug 19, 2008
Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on...
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Mar 17, 2011 | Washing Machines
Came up with fault code 37 on the screen and wont spin whats wrong with it?
Fault Code 37 is "Pump Blocked Error" which means for some reason the machine did not drain properly. This can be due to a blockage in the pump such as a lint ball or wire from a bra that got down in the pump, perhaps a safety pin, etc. It also can be caused by objects that get past the pump but become caught inside the diverter valve, which is downstream from the pump. One other thing to be aware of, and this trips people up sometimes- a pump that is failing ELECTRICALLY can also cause the same error. If the pump is overheating and shutting down, the machine will not drain and the control will properly sense that there is still water in the tub. I've suggested in the past that this error be renamed "pump error" because the term "blocked" makes people look for an absolute condition.
Feb 09, 2011 | Fisher and Paykel IWL12 Top Load Washer
Says its needs service ... Code 37 .. What is the
Consult the tech sheet for instructions on how to activate the pump and see if it runs. If you hear a "hum" sound, the pump is not able to turn and further analysis is required. Check the water pump, located in the right-front of the machine as viewed from the front. Always unplug the washer before attempting to work on it. There is an external cooling fan (black plastic) on the pump motor that you can try to spin by hand. It should offer very little resistance. If you find it difficult to turn, chances are the clog or blockage is right there in the "sump" where the pump is located.
Jan 16, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykal IWL16 washing machine showing fault 37 tub not emptying or spinning when put on spin cycyle
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Drain some of the water by hand enough to look under the machine to the front right.Do you see a fan.If you do this is your pump.If you do not see a fan then you have the new style of pump.Please reply on which style of pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
Oct 11, 2010 | Fisher and Paykel IWL12 Top Load Washer
Error 37
Hi Steve.Error code 37 means PUMP BLOCK ERROR.This means your pump is jammed or faulty or your control module is faulty.Please look under the machine for me to the front right.If you have the old style of pump you will see a fan.If there is no fan then you have the new type of pump.Please reply on which pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
Oct 10, 2010 | Fisher Paykel EcoSmart GWL15
Fault 37. Machine will not empty bowl
Hi just read your posting.Now error code 37 is called PUMP BLOCK ERROR Do you hear the pump pumping any water if you advance the cycle to spin and push the start button?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel IWL12 Top Load Washer
Error code 51? F & F intuitive washer
Hi just read your posting.Error code 51 means you have a Recirculation Fault.This means while the machine is filling or washing it loses water.Error code 37 means you have Pump Block error which means the machine is not draining.Please look under the machine to the front right and you should see a pump with a red or black fan attached.Can you confirm this please? I think there is a problem with your diverter valve and the information on your type of pump will help me rectify this problem for you.Please reply with additional information on the type of pump in your machine.Looking forward to your reply.
Jul 01, 2010 | Fisher and Paykel Washing Machines
Error code 37
37 error is 'pump blocked' It shows when there is little or no change in water level when draining.. It can be caused by a number of problems, but far and away the most common reason is that the pump has something jammed in it! It isn't a big job, but it can be tricky, and the resistance on the pump motor should be checked in case it needs replacing.. A faulty pump can damage the electronics. Empty the machine by baling it out because when the pump is removed any water in the machine will flow from the pump port. A quick job for a tech! Good luck....Nomess
Jun 10, 2010 | Fisher and Paykel GWL11 Top Load Washer
Screen has code 37 on it
Hi, welcome!
Code 37 is a "pump blocked error" code. Typically this code is triggered when the machine does not sense a change in the water level when called for. Check for debris caught in the pump, either in the impeller for moving water or in some cases, the external cooling fan impeller (exposed underneath the machine) gets snagged with a piece of fabric softener sheet (such as "bounce") and this will stall the pump and trigger a code 37.
I hope you find this info useful and thanks for using Fixya.
Jan 26, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Too many suds
Most probably a blocked or partially blocked pump.
Sep 18, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
433 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
