Question about Toshiba Equium 100 PC Desktop
Error in toshiba laptop
No hdd area error the toshiba recovery disc creator cannot be launched appear in toshiba laptop while taking recovery
  • Anonymous Sep 10, 2008
    Toshiba recovery disc creator cannot be launched
  • 779 Answers
Toshiba Factory Reset
This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
If that option is NOT available then you will need to Order CDs from Toshiba - http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/Recovery-media/m-p/9148#U9148
Posted on Apr 14, 2010
I need Toshiba Satellite L455D-S5976 (PSLY5U00Q01T) PC Notebook factory restore instruction
Hello there,
Newer Toshiba laptops usually have the ability to create recovery discs that will let you recover to "factory settings." Try this:
1. Click Start
2. Select All Programs
3. Select Recovery Disc Creator.
Recovery Disk Creator
4. Within the Recovery Disc Creator select Create
5. When prompted enter the first blank DVD and select Ok
6. When prompted enter the second blank DVD and select Ok
I hope this helps. Thumbs up if you think so.
May 04, 2011 | Toshiba Satellite L455D-S5976 Notebook
Where can I get/download free restore dics for my Toshiba Satellite a-135?
Theres restoration discs and then theres the original operating system discs,restoration discs only work under certain conditions far better to formatt and re-install operating system
Mar 14, 2011 | Toshiba Satellite A135-S4527 Notebook
I bought a Toshiba laptop satelite T135-etc I'm trying to make recovery CD, but when I open the recovery media Creator; appear a message which tells no hdd recovery area! \the toshiba recovery disc...
The recovery partition has been deleted somehow. You cannot create a recovery cd on that machine.
Sorry.
P.S. That partition isn't hidden...many think it is.
Again...sorry. Hate to be the bearer of bad news.
Good luck
P.S. You might consider using a program like Clonezilla to make a copy of your drive. Or do a fresh install.
Oct 16, 2010 | Toshiba Satellite A305-S6908 Laptop
No hdd recovery area!
have a look at this link and see if it helps you out. No hdd recovery area Google Search
Oct 13, 2017 | Toshiba Satellite A305-S6908 Laptop
NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
Oct 06, 2009 | Computers & Internet
How do i restore my toshiba laptop with the recovery cd, where can i get the recovery cd
Recovery CD is saved as a recovery partition on the system, which needs to be written/burn onto the CD/DVD.
Steps to create a recovery disc (Insert a blank DVD in the CD/DVD rom) -
1. Click Start
If you dont have the above options, you need to call the tech support and ask for the recovery disc & it will be shipped to you.
Jul 09, 2009 | Toshiba Satellite M45-S265 Notebook
I can not make my recovery disc.
Hi there.
I'm sorry to tell you that when you reformatted the drive you deleted the recovery partition and all the recovery information on it, this is why the recovery disk creator cannot be launched and is giving you an error.
Thankfully for you, you created a recovery disk before you wiped the drive so this is your only way of restoring the system so make a back-up copy of the recovery disk you made and keep it safe as the problem cannot be solved because you deleted the recovery partition.
Thanks for using FixYa!!
Jun 04, 2009 | Toshiba Satellite A100-S8111TD Notebook
Unable to create recovery disk.
Hi there.
Sounds like the software could be corrupt, but there is an easier way to create a recovery disk, check this tutorial out >>>>>
http://createrecoverydisk.com/
If you need more advice please feel free to post back.
Good luck and thanks for using FixYa!!
May 14, 2009 | Toshiba Satellite L305D-S5895 Notebook
Sound drivers for Xp sp2
For specific models with different chipset drivers, you can get the sound driver & pretty much everything else on support.toshiba.com. If you can't connect to the Internet, "Tecra, Portege", & sometimes "Qosmio" models came with a built-in HDD recovery, meaning you need to create your recovery disk by running the "Recovery Disk Creator". An application to create your recovery disk. A shortcut is created on the desktop by default, if you cannot find it there, try looking at "C:\Program Files\Toshiba\Toshiba Recovery Disk Creator" & run the "exe" file, it should give you a menu to create one. After creating the disk, you can use that disc to install the drivers for all Toshiba pre-installed devices/softwares on that machine. For Satellite models, the disc should come with the laptop when you boughtt it. When you have the disc, just insert it inside of windows, it will give you options to install the driver & software for a specific toshiba device.
Hope this helps.
Jul 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
System recovery
Hi
Please go into my conputer and check whether u have a recovery partition or not..... If you have... restart your system and tap on F11..... go to recovery partition... U'l get a pop up to create recovery cd's.... Plz create the cd's once u get the pop up
Oct 22, 2007 | Computers & Internet
Toshiba Equium 100 PC Desktop Logo
377 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
