Question about HP Cameras
Lost photographs can we get them back - HP Cameras
    President:
  • 1,114 Answers
First do not panic! It is possible to recover your pictures if you take care. Take the card from the camera (powered off) and if it has a "write protect" tab then lock it now. Do not try and write anything to the card or you risk causing more problems.
You can either plug in you camera to the PC as it should appear as a “Removable Drive” or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a FREE utility that will recover your photos from the following link:
http://www.cgsecurity.org/wiki/PhotoRec
If you need something a little more "user friendly" then you will need to buy the software. If you search the web for photo recovery software you will find many.
One I have used successfully is RescuePro that used to be bundled with some Sandisk products. Now you can get it from the link below:
http://www.lc-tech.com/software/prwindetail.html.
You can try the demo to see what you can recover before buying.
Remember - Do NOT try & write anything back to the card until you can recover your pictures to your PC safely!
Please take a moment to rate this solution & let us know if the information given was useful to you – Good Luck!
Informatica
Posted on Aug 18, 2008
SOURCE:
If I reset my blackberry curve to factory settings will I loose all my photographs?
Yes , if you will enter wrong password 10 times , then phone will be fully wiped .It means all your personal data will be lost . So try to remember your password :)
Oct 31, 2014 | RIM BlackBerry Curve 8520 Smartphone
Tip
Recover Deleted Photos From iPhone 6
It can be most aggravating when an important photograph is accidentally deleted. If you have an iPhone 6, then thankfully, there are a few options available for flv files recovery from this device. Remember, it is good practice to back-up your photographs every now and again by saving them onto an external storage device.
One of the first things to do in trying to retrieve deleted photos from an iPhone 6, is to open the Photos app on your smartphone. Once you have done that, do the following steps:
1.Select the "Albums" menu.
2.Select the album that you need and then select "Recently Deleted."
3.A list of all the recently deleted photos will appear.
4.Select the ones that you want and then tap on the "Recover" button to recover all the photographs that you selected.
5.All restored photographs will be sent to the album in which they were originally located.
If the photographs that were deleted were backed up in iTunes or iCloud, they can also be recovered. The important thing to remember is to have either iCloud or iTunes backup turned on at all times. If you are unsure how to do so, here's how:
1.Go to the "Settings" menu then select "iCloud."
2.Under "iCloud", select "Storage and Backup."
3.Then turn on the "iCloud Backup" feature on your iPhone 6.
4.As long as your iCloud backup is up-to-date, then all your photos can be easily restored to your iPhone 6 in case of accidental deletion.
Backing up your photographs to iTunes is equally as easy as backing them up to iCloud. However, once you connect your iPhone 6 to your computer or iPad, you need to ensure that iCloud is turned off; you can back-up to one or the other but not both apps at the same time.
If your photos have been deleted, then recovering your duplicate photos from iTunes backup or iCloud backup is not a problem. Simply launch iCloud or iTunes, right click on iPhone (the device in question), select "Summary", and then select either "Restore from iCloud Backup or "Restore from iTunes Backup." Once that is done, wait for "Restore in Progress" to complete and your device restarted.
When all else fails, a reliable data recovery software can be used to recover deleted photos from an iPhone 6. uFlysoft is one such user-friendly software that gets the job done quickly and thoroughly. The process is simple and takes these easy steps:
1.First, connect your iPhone 6 to your Mac computer then launch the uFlysoft data recovery software. You never want to launch a data recovery software directly from the smartphone from which you are trying to recover lost or deleted data.
2.Select the "Recover from iOS Device" option.
3.The software will then scan your device and present all the recovered photographs for you to preview.
4.The recovered photos can then be saved to any storage device or the computer itself.
RE: http://www.uflysoft.com/
on Feb 11, 2016 | Apple Genuine Original Iphone6 Earphones...
Can I recover lost files and photographs?
yes, you can recover lost files and photograph with file recovery software like asoftech data recovery, download the program from
http://www.asoftech.com/adr/
May 16, 2010 | Computers & Internet
I've lost all photographs on my phone they were there yesterday, but have all disappeared. I have taken the battery out several times but this hasn't helped. I would really appreciate any help as my babies...
U can try this 1st method, try to unplug your M2 memory card from your phone (locate at the left bottom part of your phone) and replug it back. If still cannot try to use the M2 card reader to read the card content.
If your picture is not in the card, then it is in your phone memory. Try this following 2nd method, install the software Sony Ericsson PC Suite, connect your phone to your PC through the USB cable provided from your Sony Ericsson phone pack. Try to browse into your phone data system and see whether your pic is inside or not.
If the above methods aren't work for u then your memory may have defective. U then have to use the recovery software to recover your memory data. And this need a lot of steps. Try the above method 1st and we'll see then.
YBC (/\)
Oct 13, 2009 | Sony Ericsson Z610i Cellular Phone
I have a D40 and have been able to use he LCD monitor as a view finder, somehow I lost this ability and can't seem to get it back. Any ideas. I lost it several months ago and another photographer was able...
If you were able to use the LCD monitor as a viewfinder on the D40, then there was something wrong with your camera.
The D40 does not have a Live View capability.
Sep 19, 2008 | Nikon Cameras
When I view my photographs on my Nikon D50 the white on the photograph pulsates with black where the white areas are on the picture. The photographs itself is perfect but this is annoying. Can you help...
You're looking at the blown-out highlights. These are areas where you've lost all detail. Press up/down on the multiselector to change the view. Better yet, reduce the exposure to reduce/eliminate them.
Aug 10, 2008 | Nikon Cameras
D80 ERR & CHR message
Hello Michaela1,
There are a few things I can recommend:
1. Please check your card on some other camera to make sure the media is alright.
2. I am not sure if you take the SD card out of the camera and put it into a card reader (stand alone, in your laptop/PC) to read the images. As I understand, you first took out the card and then put it back into the camera to read from the camera once it did not work in the card reader. However, there are issues with doing both. I will outline them below.
  • Card Reader: At times, reading a card in a card reader will mess it up and it will remain unusable in the camera even if it displays photographs on camera LCD. Please note, this will happen even if you have only viewed the photographs on your computer and not saved them to your hard drive/media. The card will most definitely not work in camera if you delete photographs from the card or edit them on the card. The only solution to this is to format that card IN the Camera. The manual has instructions for the same.
  • In Camera: Other times, you may have connected the camera through the USB cable to a computer with the card in the camera. This problem may crop up IF you used your computer to delete images from the card whilst it was IN the camera. Again, the solution is to format the card. IN the camera, not from the PC.
3. Whether you use the USB cable or take out the card and put it into a card reader to save your photographs, always repeat ALWAYS format your card in the camera after transferring your photographs. This ensures card will not malfunction unless the media is corrupt. This also has the added benefit of not having the same photographs a few times over.
4. Try not to leave your images in the card after taking photographs. Try to save them to your PC at the earliest opportunity. Format after-wards (I can not repeat this point enough).
5. Use multiple cards of smaller capacity. They are cheaper to buy. Even if you lose one card to a mal-function, you still have photographs on others.
I hope this helps.
Satdeep
May 31, 2008 | Nikon D80 Digital Camera with 18-200mm...
File error
It could be either. There is not any way to tell, but if the problem is too bad I would replace the memory card first and then address the issue within the camera if it continues. David Millier Advance Camera Repair
Feb 03, 2007 | Sony Cyber-shot DSC-H5 Digital Camera
Cameras Logo
24 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
