Question about Philips 190B6CB/27 19" LCD
Philips 190G -> http://www.cnet.com.au/i/r/2006/desktops/monitors/22139625/Philips_190G6FB-97_c.jpg
The monitor randomly lost the picture. The lamps are green and everything seems fine except the actuall picture. What can it depend on?
The monitor is relative new, think it's 1 year old.
The picture disappeared and now the picture is all black...
thanks / Dennis (dempa887@hotmail.com
  • 3 more comments
  • mcrae100 Oct 08, 2008
    My phillips 190g is not quite 3 years old and the sceen is black all of the time no matter what input method I use.I'm very dissapionted with the life span off this well known top brand unit.I thought it should last at least 5 years or so!
  • phase26 Oct 15, 2008
    I have the exact same problem, the screen went black. I actually by accident turned on a headlamp and when pointing at the monitorscreen I can weakly see my desktop... I am now writing this with help from my headlamp on my otherwise black screen. Everything else seems to function correctly... what to do?
  • kennywisse Oct 31, 2008
    I have the same problem, one day my screen was fine and then the next it stopped working everything else works bar the screen it's just black. is there anything to fix this or is the screen blown?
  • elby_designs Mar 10, 2009
    When I power up the monitor you get a flash of the full PC screen for about 1 second and then the screen goes black. I am guessing this is a problem with the backlight.
    Has anyone resolved this or a similar problem?
  • Anonymous Mar 23, 2014
    true or false
My solution:
Open the monitor. Take off the mainboard. There´s a supply board for the backlight under it.
Replace the two purple capacitors (150uF/25V). These are from a bad batch.
Also replace fuse F1 (lightbrown SMD-component) on the bottom of that board (near the long side).
It has blown as a result of the bad capacitors.
In my case the values were dropped to 25 uF. And the internal resistance (R) was more than 2 ohms.
That´s it. Hope it helped you.
Posted on Jan 27, 2011
  • Nyholm Sep 09, 2012
    For the Fuse what value is it 2.5A and what volt and were did you get the fuse?
Philips 190G having issues using it only as speakers. Stand-alone Speakers mode
Your TVs sleep mode is activated. Disable it on your TVs menu under settings http://download.p4c.philips.com/files/1/190g6fb_00/190g6fb_00_dfu_aen.pdf also d/l new drivers for your monitor and install them.
Mar 09, 2015 | Philips Computers & Internet
Philips 190G
My philips 190g hase a five cents size blue spot on screen how do you get rid of if possible
Dec 22, 2013 | Computers & Internet
What size ccfl and how many are in this unit?
Look here on how to figure out: www.lcdparts.net
2 lamps.
May not be worth to replace the lamps in 15" monitor, beside, are you sure it is the lamp problem?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 26, 2011 | Philips 150S (White) 15" LCD Monitor
Hi, I got problem with my 226BW Samsung. Some time it started. The blue light on the monitors blinks (normal) but no picture, also not menu or anything. After a few minutes it blinked shortly and than it...
Sorry, the links you provide does not work. You can post the picture her at FIXYA but it has to be less than 150k in size.
Do you see caps with dome top (not completely flat)?
Jan 11, 2011 | Samsung 226BW Monitor
My backlights for my Philips 190G Monitor is very weak. The screen is black, but when I point a lamp against it, I can see a see some picture but its like the contrast is on the weakest point. Its a...
Not likely to be the lamp (but not 100% sure), more likely to have bad DC caps problem.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
Aug 20, 2010 | Philips 190B6CB/27 19" LCD
Philips 170V LCD screen steadily blinks on and off, even when not
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 13, 2010 | Philips 170V6FB (Black) 17" Monitor
Black screen (Philips 190G)
check the brightness / contrast control
do you see OSD (On Screen Display) Menu clearly?
Feb 08, 2010 | Philips 190B6CB/27 19" LCD
190g ajutor:):)
no mai fi bun cablul de alimentare dela monitor ancearca alt cablu daca nu mere dul la reparat
Oct 05, 2008 | Computers & Internet
Please help me:(((( 190g
Oh... poor 4cs,
Sorry to tell you, but you've got unlucky! Your Phillips 190g backlight inverter got fried due to over heating. Need to replaced a new inverter. Good lucks!
Oct 02, 2008 | Computers & Internet
Philips 190B6CB/27 19" LCD Logo
1,200 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
