I've pulled up the user manual for your phone. Thank you for providing the phone make and model first, and the complete description of your issue!
The manual says the battery should be charged for 15 hours before first use.
You may be set to pulse dialing , even though the factory default is for tone dialing. If you push the 7 key, you would hear 7 pulses or clicks in succession. The dial tone will be gone once a pulse has been received. And you say there are clicks heard and no dial tone.
You can set Handset settings (Page 12 in the PDF copy) and customize how your phone works.
Hit MENU and use the up-arrow and down-arrow keys to scroll to the desired feature., this time called DIAL TYPE, then his SELECT. Looks like the sixth menu entry from the top after LANGUAGE.
It should read:
DIAL TYPE
TONE
If it says something else, perhaps PULSE, use those arrow keys again to change the Dial Type to Tone. Then use OFF to back out of the selection and again to clear the menu.
Attached is the link to the manual. Click the button on the screen to "Open as PDF" and you can open it in your PDF reader software or save it to your device for offline reading.
http://phone.manualsonline.com/manuals/mfg/att/e2125.html
SOURCE: 2355 at&t phone
you will need to call att or manage your phone online at http://www.att.com/gen/landing-pages?pid=3308
SOURCE: unable to register handsets to
From the manual:
1) Before registering the extra handset, the battery pack MUST be charged for 15-20
hours.
2) With the main base in standby mode, press the MENU soft key on the base.
3) Press /vol/∧ or /vol/∨ on the base to select H S R e g i s t r a t i o n, and then
press the OK soft key.
4) On the handset, press and hold # for two seconds. To cancel registration, press
the CANCEL soft key on the base.
5) While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the Handset
LCD. When R e g i s t r a t i o n C o m p l e t e is displayed, the handset has been registered
to the base. If R e g i s t r a t i o n F a i l e d appears, please try these steps again.
Geno
SOURCE: Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
SOURCE: Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
SOURCE: Register additional handsets on a Uniden phone
On most models you can find an option in the menu for De-register?
In that case you would select that option and select to deregister the
handset.
TRU88 models you go to the main menu and go to De-register HS select yes to deregister the Handset.
DCT5 and DCT6 models: Press menu on the handset. Go to System Reset and Press select. Go to Deregister HS and press select. Arrow up to yes and press select. Then go back into the menu. Go to system reset and press select. Arrow down to Replacing the base and press select. Arrow up to yes and press select.
DCT7 models: Press and hold "end" and "#" until the system reset menu appears on the display. Then follow the instructions from above for the DCT5 and DCT6 deregister procedures once your into the menu.
TRU4 and TRU5 models: Press and hold xfer/del and end until "de-register?" appears. Use the plus+ button to go up to yes and press select.
To register any of the following phones please see you owners manual under either:
•Register handset or
•Register the digital security code.
