RCA P46738AT 46" rear projection No Power
I just aquired an RCA P46738AT television set made in 1994. The TV makes a quiet charging noise when it is pluged in but when the power button is pressed the green light flashes on for a second and then off with no power. I suspect that it is an HV board but am not sure wich one. If parts are even still available can you please help me trouble shoot and locate parts for this. I am a repairman with muti-testing and soldiering skills but I am lost without some guidance on this one.
Hi i have the same situation with my rca same model number, did you ever find a fix for this??my email is [email protected] please let me know
Posted on Sep 06, 2008
SOURCE:
I just acquired an RCA P46738AT television set made in 1994- 1995. The TV makes a quiet charging noise when it is plugged in but no light on the power button and no power. Not sure what to do about this...
This is a common problem and chassis (CTC169) and it sounds like the HV block is bad. Part# 205064. Caution is required when replacing since High Voltage is present.
Sep 27, 2009 | RCA Televison & Video
The picture is wider then the screen on my rear projection tv
Are you using a cable box? Do you have aspect settings on your remote? Comcast cable boxes have a hd zoom button. This will push the sides of the picture out
Apr 22, 2009 | RCA P46921 46" Rear Projection Television
RCA P46920 TV will not turn on, it makes a beeping noise.
Shorted horizontial output transistor q14401 -I think- and bad flyback transformer(high voltage transformer).The noise is the power supply starting and shutting down very quickly because of the shorted transistor.Very common problem,but some of the flybacks are no longer available from RCA.Sometimes you can use generic but questionable life on some of these.
Jan 11, 2009 | RCA P46921 46" Rear Projection Television
RCA P46924 46 in rear projection tv will not turn on
More than likely it has bad solder connections on the circuit board. You could try tapping lightly on power supply/deflection boards to see if it makes contact. Usually I find bad solder on those right under where the power cord plugs in, on the bottom of the board. If you have a soldering iron and solder you could save a few hundred dollars in repair costs, but use caution and make sure all power to set is disconnected. Maybe mark each plug as you disconnect them. Hope this helps. Good luck, Russmann.
Jun 02, 2008 | RCA P46924 46" Rear Projection Television
Will not turn on
start up circuitry needs trouble shooting probably one of the regulators or flyback.
Mar 13, 2008 | RCA P46921 46" Rear Projection Television
RCA Projection TV
ok lets begin... shut off? ...is the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv will not yurn on.
Easy diagnosis = bad flyback.............P46921YX1 = # 239111
P46921YX4 = # 250694......................................T.
Dec 13, 2007 | RCA P46921 46" Rear Projection Television
Phillips 60'' projection hdtv wont turn on
Question do you see green led or light when pressing power button? If you can also listen for a high pitch noise coming from back of set. This would be an indication that the set has powersuppy problem or high voltage problems. If the set is dead and no noise then maybe fuse or open circuit.
Aug 13, 2007 | RCA P46924 46" Rear Projection Television
Tv sounds like it wants to turn on but doesn't???????
Probable bad HV block ....Provide service number off back of set for verify part # 205064............................................T.
Apr 01, 2007 | RCA P46921 46" Rear Projection Television
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Ekse
