Question about NetGear WN121T (WN121T100NAS) Wireless Adapter
Wn121t won't connect to the router
I have a range max wireless n router that is connected to a desktop (wired)
I'm tring to connect another desktop with the wn121t. I have downloaded the vista drivers and it all installed fine but it keeps searching but won't find a network.
I have spoke to netgear, they said to change the channle to 6, still hasn't made a difference.
The computers are far apart, thats why I brought the netgear stuff to solve the range issue.
Please help
Thank you
  • gdoss Sep 02, 2008
    Using all netgear. wn121T will connect, but not stay connected. It bumps on and off about every 20 seconds. I am less than 10 feet from router. have moved 121 everywhere possible. I have two gateway laptops that have almost no trouble with connection and they are 55-60 feet away. I downloaded new drivers today and still no help. It worked at this location two weeks ago. Any ideas?
  • 854 Answers
No Wireless Connection Found in Range
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing or in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click the Wireless Settings under Advanced tab.
5. Check the box under Enable Wireless Router Radio and Enable Wireless SSID Broadcast.
6. Click the Wireless Settings under Setup.
7. Change Channel (recommended are 1, 6 and 11).
8. Change the SSID to uniquely identify your network. You might have a similar SSID with your neighbor.
Note: Do not change the SSID if there are already other wireless computers that can connect to the network.
Other factors that you may consider when you are not able to view any available wireless network:
a. Switch for the wireless adapter is turned off
b. Distance between the wireless router and computer
c. Possible wireless interferences
Posted on Aug 16, 2009
Using wireless laptop for internet connection toNetflix on TV while traveling instead of desktop router at home and the SSID is not accepted--error 51032. How can I get a different access SSID? Also, on...
When you use your wireless-enabled computer far outside the range of your wireless-enabled router, you definitely will be trying to connect to a different wireless-enabled router.
That "foreign" router will broadcast a different SSID than your router is broadcasting.
Use "View Available Wireless Networks" to find that SSID, and "connect" to it.
> all of my options are ...
Jul 08, 2011 | Computers & Internet
Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
The range expander helps to extend the range of wireless network...
Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
Site survey searches for the available wireless networks in range...
It should show your existing wireless network...
You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
Thats it...
You are done...
Your wireless network range would have extended now....
Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
Tring to use a wireless n usb on a g router
Make sure to use the wireless utility of your wireless N adapter and not the Windows Wireless Zero Configuration utility. You can also change the wireless channel of your router to channel 11 and power cycle the router by turning it off for 30 seconds then turn it back on. Try to connect again. Make sure firewall on your computer is disabled.
Apr 15, 2009 | Belkin (F5D7230-4) Router (587009)
WN121T Adapter constantly loses connection. Othe wireless adapters work fine without drops. I'm using Vista, driver version is 10/26/2007. Router is TP LINK (N)
Try swapping adapters from another of your machines, this one may be faulty. Location may also be a factor, try to locate so that antenna unobstructed from router.
Hope this helps
Feb 01, 2009 | NetGear WN121T (WN121T100NAS) Wireless...
Need help with connect a d-link,dl 624 router
You wireless router/access point can host several simultaneous connections to the internet. Just connect your laptop to the wireless network as you would from your desktop computer.
Hope this helped.
Jul 11, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Hi there, I just bought a netgear Rangemax next wireless router WNR834B with RANGEMAX™ NEXT WIRELESS N USB 2.0 ADAPTER – WN121T with no installation CD and i have connected the router to my modem and its...
Get the driver for the WN121T from the NetGear webset and install it before pluging the adapter into the notebook. Use a wired connection on the notebook until you have the drive downloaded.
Jun 19, 2008 | Computers & Internet
Hi I have for
is your adapter recognized in the device manager?
Feb 15, 2008 | Computers & Internet
Wireless connection
Try turning off encryption on the router. If you can connect after that it is an encryption problem.
Dec 25, 2007 | Computers & Internet
NetGear WN121T (WN121T100NAS) Wireless Adapter Logo
214 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
