Well, it means that you still have a pending job (fax).
if you really want to erase all the jobs, you must enter to the service mode.
press:
fax button
function
7
monitor (4 times)
asterisk(*)
find for ram initialize
find for all job clear
note: must be sure to select the "all job clear" only
set.
restart your machine
Call service 3 coming on panasonic DP-MB300I not able to print and xerox in my panasonic DP-MB300,the machine is around 3 months ago from buying.please help this problem.
i got my dp-301u to work fine with my hp1020 on 2 different
workstations with the following steps.
1. install printer locally via usb and test. 2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it. 3.
once created go into the properties of the 2nd printer and change the
port to something local - anything will do to free up the port. 4. go into the properties of the printer that was created in step 1. and change the port to that of the print server. 5. test print. should work fine.
"XMT/RCV password does not match. Last 4 digits of TSI does not match with the last 4 digits of the ONE TOUCH, ABBR Telephone number." This is straight from the Panasonic service manual. I would suggest looking in the User's manual uner "passwords" and try to either reset or clear out the password info.
Hi, Error (004) as displayed in your printer refers to the option setting (output tray) that you set in your printer properties in your PC. (Assuming you are running WinXP) Start. Printers & Faxes, Right click on PX 150 and click pproperties, Printing Preferences. Set output tray.
More details are availbale from http://panasonic.co.jp/pcc/products/en/mfp/download/dp-c322/ps/opc3psen.pdf
Hope this works out for you. Godd luck
