Your problem is more likely to be the card, not the PC. First, try using a different card. If your laptop shows a new drive letter(in computer folder) then you will know it isn't your PC.
* check the slot might some pin is dislocated due to wrong insert of SD card
* try to use a multi media card reader if will work.when if works.
* then your laptop SD card slot has the problem.
