Question about Garmin Nuvi 660 GPS Receiver
Garmin always 1/2 mile left of actual position
Hi, my garmin always shows half mile left of actual position, when i entered the actual coordinates of my position ( got the ref from another gps), garmin actually plotted a route ( from the the garmin's present position) to the coordinates ( which is my actual position, correctly showed up in garmin map). So is it a map problem or a unit problem ?
thanks
  • 53 Answers
It could be the unit or the film on the windows of your car .... most of the time it is the unit messing up i have ran into this problem a few times installing
Posted on Aug 31, 2008
How do i insert a coordinate to find a spesific fishing spot
The Garmin nuvi's were designed as automotive navigators and not really designed to be used as marine or outdoor GPS units with the exception of the nuvi 550 which is an all around GPS.
The Garmin handhelds are recommended for marine and off road recreational use but it is possible to navigate if you know the coordinates of your fishing spot.
To enter coordinates: Touch Where to? > Coordinates and touch a box to enter a coordinate.
You can also refer to the manual for more information. nüvi® 215
Sep 22, 2011 | Garmin nuvi 215 GPS Receiver
How to find a position from GPS coordinates?
If you know the proper geographic coordinates of your destination, You can easily navigate around your destination using the longitude and latitude coordinates or other coordinate formats.
  1. Touch WHERE TO on the screen,
  2. Touch COORDINATES from the list,
  3. Touch FORMAT to change type of coordinates. Because different maps and charts use different position formats, the nuvi allows you to select the correct coordinate format for the type of map you are using,
  4. Enter the coordinates and touch DONE.
That is how you find a position using the coordinates, but you have to be very familiar with coordinates to be able to use it.
Complements of the season to you over there.
Dec 25, 2010 | Garmin GPS
I have a Garmin etrex handheld unit. The gps data from it does not correlate with google maps gps coordinates at all. There is a 30 mile, not feet but mile difference in the waypoints. Any idea what I may...
You need to make sure your GPS unit and Google maps are using the same map datum.
In your user manual:
http://static.garmincdn.com/pumac/eTrexLegend_OwnersManual.pdf
Page 44, Setup Options, Units, Position Format: I suggest setting to:
hddd.ddddd as this is the digital format and easier to read
In Google Maps, right click - Drop Latitude/Longitude marker and this should show the co-ordinates in digital degrees. Alternatively, you can hit the SEND button in GoogleMaps, and it will send the marked location to the GPS via the Garmin website. You may have to install the Garmin plug-in into your browser first, but it's well worth it.
If this solves your problem, please come back and rate our solution, thank you.
Dec 19, 2010 | Garmin eTrex Legend GPS Receiver
How do i enter gps coordinates into my garmin etrex hc
Hi Jdriscoll38,
Since you probably have been using this device, you know it will automatically receive and lock in on the coordinates from at least three satellites if you move outside to a large cleared area, and power up. I could list all the steps to manually set all the coordinates, and that would take a couple of pages. Download the entire 56-page manual at this site, and refer to the pages below:
http://www8.garmin.com/manuals/eTrex_OwnersManual.pdf
Go to the top of page 20 to change the Position Coordinates.
Right below those instructions, you'll see the info for changing the Elevation.
In case you don't have this manual, after download this, you should have all the instructions you need for all operations.
Let me know if I can help further. Thanks.
Regards, Bill
Sep 18, 2010 | Garmin eTrex GPS Receiver
Trying to add favorites in a new Garmin Nuvi 265
There are at least three ways:
  1. At the GPS position and you want to save it, select the car image (or what ever you use for your position) then Save. Then you will be prompted to enter the Name then Done and then Save to Favorites? Select Yes.
  2. Enter the address, if it is found, then select the car image. The rest just follow no. 1 above.
  3. Enter the coordinate. If it is found, then select the car image. The rest just follow no. 1 above.
Aug 25, 2010 | Garmin nuvi 265 Car GPS Receiver
We are going to Europe and using Camping Cheques Brochure but the GPS Coordinates are as such L49degrees 0'10"1:2degrees56'28" but my Garmin Sat Nav Coordinates only give me a choice of N,S,E,or W can you...
I would suggest that you go to a web site that will take those co-ordinates that you have, enter them and then get or have the program show you the other co-ordinates that you need and can use, Also you may want to check in the sub menu on the gps unit, sometimes some of them have the ability to switch to different co-ordinate system, but this is sometimes, not always. Hope this helps
May 10, 2010 | Garmin nuvi 255W GPS Receiver
Cannot find gps cordinates
Actually some GPS units do not show coordinates. Make sure you have one that does. A lot of the early Garmin units didn't have coordinates or a way to enter new ones.
Apr 20, 2009 | GPS
Negative coordinate
By entering a negative longitude as a positive degree West of the prime meridian. For example, -4 degrees is entered as W 4 degrees.
May 30, 2008 | Garmin nuvi 350 GPS Receiver
Garmin 45
If you know your coordinates, enter them on the position screen.
Use the track pad to highlight the coordinates on the position screen. Press "enter".  Use the track pad to change the digits to match your current position.  Place the GPS where it has a clear view of the sky and wait.  If you have a power cord, plug it in as it may take as much as half an hour.  Do not move the GPS while it is trying to acquire.  The antenna should be vertical.
If the GPS still doesn't acquire, it may have lost the satellite almanac data, which has changed since that unit was manufactured.  I could not find a software update on Garmin's website for that model, however, it is possible to transfer the almanac data from another garmin.  Post a follow up message here and I can give you more instructions if needed.
Oct 29, 2007 | Garmin GPS 48 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
175 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
