Check if
* might the flex connector/cable is dis-align or got loose contact.
* LCD components (some parts) are curroded and need to be clean
if you do it on your own,take a little care of opening it.
On Top (LCD screen housing) : just use a guitar peak in between the housing
On Bottom (Circuit boat) : unscrew all side and corner of it..(beware of hidden wires and flex connectors.
* using hot air or a hair blower... target the LCD components attach at the back of the screen,maintain the temp cause my burn the screen and assemble it properly and fit each socket.
if you got the same problem... might need a replacement and bring it to a authorized service center...
good luck.
