SOURCE: Doesn't work/open you tube website
If you want to open youtube website, connect to the net and type www.youtube.com in the address bar to open the website.
Kindly rate my help+ Thank you
SOURCE: I am using google chrome
The speed of the page load is depending on the ram memory ..the cpu capacity ..and the operation system you use...so ..if the system do not support that well the windows 7 this may be the cause...Also a the cpu is to blame for a low speed in case it is under 2000Gz and running windows 7 ..Another issue is the connection to the internet...the loading of the page is dependent of the traffic speed your connection is capable of ..so ..if your laptop is on wifi ..check the router's settings for enable maximum speed..
To be sure it is a speed issue ..just make a speed test and see what speed you have on the desktop and what speed on laptop ..and you will see the difference ..
Keep in mind that if you connect the laptop to the cable and in one of the router's ports ..it will have the same speed as the desktop ...The wireless should have almost the same speed too ..but in some cases if the settings are not made right , it is limited..on a ridiculous low one ..
SOURCE: Why won't my browser allow
Hi, If this problem is still occurring for you and is only specific to Google Chrome, can you try clearing your browsing data to see if that helps? To clear your browsing data, follow these steps:
1) Click the Wrench menu in the upper right corner
2) Select "Tools"
3) Select 'Clear browsing data'
4) Ensure that check boxes for 'Clear browsing history' and 'Empty the cache' are selected
5) Click 'Clear browsing data'
I hope this helps.
eibraz
