Question about Freezers
MAIN RCD CIRCUIT TRIPPING OUT
NONE OF MY SOCKETS WORKED IN MY HOUSE THIS MORNING SO I CHKED THE TRIP SWITCHES AND THE MAIN RCD ONE HAD TRIPPED BUT EVERY TIME I TRIPPED IT BAK ON IT WNT OFF AGAIN SO CHKED ALL SOCKETS AND IT CAME BACK TO MY FREEZER.I CANT GET IT TO STAY ON PLZ HELP
  • Freezers Master
  • 1,300 Answers
It may not be the freezer. ground fault recept. are known to go bad pretty regular. upplug freezer and see if it still trips. It doesn't take much to trip one, so look for something simple
Posted on Feb 13, 2009
SOURCE:
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
My freezer keeps overloading our switch board, whats wrong?
The freezer has a compressor which will draw quite a lot of current in the first half-second when it starts.
Either: Your freezer has a electrical problem and needs to be fixed,
Or: there is already too much drawing on the circuit that you are trying to add the freezer to, and the freezer is more than the circuit breaker will allow.
First try powering the freezer from some other socket on a different circuit (use a long cord), or unplug a few things that are nearby (in most houses, there will be several wall sockets on the same wire in each area of the house).
If the freezer runs fine from a different socket, or when you unplug some other stuff, then the problem is you are overloading the circuit you were originally trying to add it to.
If you can't get the freezer to run on any socket without tripping the circuit breaker then probably the freezer has an electrical fault and best you get a real electrician to check it (safety first!).
Oct 02, 2012 | Freezers
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
Tripping electricity
HI, The reason for the over-pull is due to the unstable conditions located at the main PCB that controls this affected unit. The voltage is not stable, due to the damage located at the PCB(circuit instabilities). Just to be safe, have your local electrician inspect the breaker box for shorts and damage to the appropriate circuit block. If the electrician confirms that the breaker is in good condition; replace the main control board(PCB) that is mounted near the compressor or behind the rear access panel.
Jul 21, 2010 | Whirlpool Freezers
My GS28v00GB001 upright freezer trips my RCD. I've replaced nearly every electrial component (capacitor) Starter device, Sensors and still it does it. Initially it runs for a number of hours till it trips,...
I am not familiar with Bosch but I do know that other brands use the defrost heater as a source for power to the compressor while running. If the heater is partially grounded it could cause this problem. If this is okay have your thought that maybe your RCD is going bad... just a thought
Apr 24, 2010 | Bosch Freezers
Red light on, tripping the fuse box
Need to know if it's tripping a breaker or an RCD.
sound like an earth fault and tripping the protection.
you need a qualified professional.
Mar 27, 2010 | Freezers
Hi There, My freezer is less than 3 years old. (MQU1656BEW) It seems to be tripping the GFI plug in our garage. (It is not plugged into this plug, but is on the same circuit.) I have plugged it into an...
Refrigerators and freezers should not be run on a GFI outlet the it will weaken and start tripping.Most manufacturers now print this in the owners manual.
Aug 17, 2009 | Maytag 15.6 cu. ft. Upright Freezer...
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Freezers Logo
259 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
