Question about Nikon F65 35mm SLR Camera
Nikon F65 power switch button issue
When I turn the camera on and keep inthe Auto mode, I try to press the power switch button to take a pic. But this is not releasing and its very hard. But the lens keeps changing the focus. I am not sure where the problem is.Could you pls help me?
Cheers
    Novelist:
  • 121 Answers
Rads_london,
Sounds like you have been shooting in one of the manual modes, make sure if you have been trying different F-stops to change the aperture ring back to it's auto position (red numbers F-22 usually) to align with the white dot on the lens. That way the camera and lens can agree on the amount of light needed and how much the shutter will open to allow light in. The camera won't take the shot if it is way off (kind of a safety). Use the viewfinder to learn what combinations the camera needs for a particular shot so you can be familiar with the speed and aperture settings, try them in one of the manual modes and you will be pleasantly surprised with the results. Soon you won't shoot as much in auto mode.
randy320sgi
Posted on Jan 15, 2009
Nikon D5100 camera flash does not pop-up. Any suggestions?
You can't pop up the flash in the Auto mode. In this mode the camera decides whether to use the flash or not.
Try switching to one of the PSAM modes. Does the flash then pop up when you push the flash button?
Jan 17, 2014 | Nikon D5100 Digital Camera
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
This is kind of embarassing... i received an old nikon f65, and i don't know how to remove the film properly without burning it...
The film should rewind automatically at the end of the roll. If it doesn't, press the two film-rewind buttons simultaneously for about one second. The film rewind buttons are maked with a red film icon; one is also the exposure compensation button to the right of the LCD control panel, the other is the auto exposure bracketing button to the left of the viewfinder.
Once the film is rewound, turn the power off. Slide the release lever on the left end of the body, and the back should pop open a little.
You can download the manual from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Aug 23, 2010 | Nikon F65 35mm SLR Camera
Nikon F65 35mm how to change the aperture
If the lens has an aperture ring, it must be locked at the mininum aperture (largest F/number). In PSAM modes use the command dial (possibly in conjunction with the exposure compensation button) to change shutter speed/aperture.
Sep 30, 2009 | Nikon F65 35mm SLR Camera
Canon 3000N Auto focus fault
No extra batteries.
Usually this is a lens fault as the focusing gear is all in the lens. Clicking sounds as if a rear pinion has cracked. It's not uncomon in the 'prosumer' level lenses where plastic gears are used a lot.
It's just possible the fault is which the auto-manual switch. This usually has a mechanical clutch coupled to it which physically disconnects the gearbox from the focusing ring, as well as operating a switch to tell the camera to turn off the AF system.
Dec 21, 2008 | Nikon F65 35mm SLR Camera
Nikon f65 slr
annlane123,
Since you have been taking photos in one of the other modes, say shutter or aperture mode you may have changed the F-stop in the process, check to see that the ring is set back for auto mode by aligning the red numbers (ususally F-22) to the white dot on the lens, that way when the camera in auto needs more light the lens will open enough to allow it. Test it with the metering in the viewfinder you'll see it as you change to each number. Remember both the lens and camera are communicating with each other. Not allowing the shutter to release is kind of a safety.
randy320sgi
Aug 27, 2008 | Nikon F65 35mm SLR Camera
Camera freezes when changed from Auto > Scene
Nikon Coolpix s3 powers on OK when switch is on auto mode, but when switched to "Scene" mode cannot shoot, switch back to auto mode / movie mode, or turn off. If power is turn on when switch is in "Movie" mode, everything is OK. Help!
dr rajeev jain
drrjain3@rediffmail.com
Apr 15, 2008 | Nikon Coolpix S3 Digital Camera
External flash problems
Sounds like the external flash is being triggered by the pre-flash.
On the D40 set the flash mode to manual. On the F65 set the flash mode to Standard TTL.
Nov 28, 2007 | Nikon F65 35mm SLR Camera
Error message
Your camera probably doesn't have a problem. Mount a lens on it and turn the aperture to the smallest opening = F/22 or F/32 then try it.
Nov 05, 2006 | Nikon F65 35mm SLR Camera
Nikon F65 35mm SLR Camera Logo
134 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
