Question about HP Computers & Internet
My HP vs15 monitor just died. It comes on and everything looks good for about 1 second, then just goes blank. My question; should I toss it out or attempt ot have it repaired. I know nothing about this type monitor so your advice will be greatly appreciated. Thanks
  • 114 Answers
If it is a tube type monitor, (i.e. not LCD) I would suggest replacing it.
Posted on Aug 18, 2008
IBM 8303 DOESN'T SUPPORT MY FLATSCREEN HP VS15
2 steps:
1. plug the hp vs15 into another computer and see if it works, if not could be a bad monitor.
2. If you have the old monitor, plug it in to the IBM computer and in windows lower the resolution down to 640 X 480. Now turn off the computer and plug in the VS15 monitor. If resolution was an issue it should work now.
Hope this helps
Jan 31, 2012 | IBM Computers & Internet
My monitor (HP vs15) is flickering for about 5 seconds and then goes black. I managed to get it to turn back on and stay on, but now it is very dim.
It sounds like the LCD inverter is dying.
It would be cheapest to have it repaired but it would make the most sense to buy a new monitor.
If you have it repaired it might just be another part that dies next week.
Mar 06, 2011 | HP Computers & Internet
Vs15 (Gray, Metallic) 15 in. Flat Panel LCD Monitor: you mash the power button and the light will come ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | HP vs15 15"LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
Monitor is bad for sure. Try another known good monitor on your computer and if the problem stops then you know for sure the original monitor is bad. Hope this helps.
Feb 01, 2009 | Dell Dimension 3000® Pentium® 4...
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
the moniter may be having  some technical errors   maybe the IC's has got corrupt
you need to call the seller of the moniter
Sep 06, 2008 | BenQ FP71G 17" LCD Monitor
Monitor stays asleep
Check in the BIOS and see what your monitor settings are.
Did you change the sleep mode or power off mode? What do you do to make it come back on? Sounds like it might be getting too hot and/or going bad. Try it on another machine and see what it does. Also try another video card because the video card could be going bad.
May 30, 2008 | HP vs15 15"LCD Flat Panel Monitor
Hp vs15, black screen, power light goes on and off like it is in sleep mode
Monitor is dead. The LCD inverter board probably went out and needs replacing. More than likely, it will cost you over $100 to get it fixed. It's better to spend the money on a new monitor.
Jul 13, 2007 | HP vs15 15"LCD Flat Panel Monitor
Computers & Internet Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
