Question about Whirlpool Washing Machines
I just recently purchased the Duet washer.. I attached everything according to 'spec' but an error code appears.. F37.... and then F28. What is the problem? I didn't think a new washer would give me such grief!!
  • 1 more comment
  • jumbalaya Aug 18, 2008
    Duet.... front load.... don't have model #
    ok thanks....
  • jumbalaya Aug 19, 2008
    model #WFW9400SU ser# CSU4905370
    Fault code F32
  • 594 Answers
What is the model of your washer so i can research the error codes for you.
Posted on Aug 18, 2008
  • Cameron Viseth
    Cameron Viseth Aug 18, 2008
    ok i am going to need the model number because the codes change with each model. the model number should be under the lid on a white sticker.
  • Cameron Viseth
    Cameron Viseth Aug 19, 2008
    Washer displaying code message and tone sounds
    “F20” (Water Inlet Problem—no water or insufficient
    water supply)
    Select PAUSE/CANCEL twice to cancel the cycle. Unplug
    washer or disconnect power.
    Check the following:
    Are water faucets completely turned on?
    Are screens at inlet hose connection to washer clogged?
    Are water inlet hoses kinked?
    Are water inlet hoses frozen?
    Plug in washer or reconnect power. Re-select cycle and press
    START. If the problem remains, call for service.
    “F21” (Drain Problem)
    Is the drain hose kinked?
    Is the drain hose frozen?
    Is the drain hose clogged?
    Is the drain hose more than 96" (2.4 m) above the floor?
    “SUD” (Suds Routine)
    When excessive suds are detected, a suds routine
    automatically starts. This routine removes extra suds and
    assures proper rinsing of your garments. “SUD” is displayed
    during rinsing and at the end of the cycle to inform you that
    Suds Routine was activated. Use only HE (High Efficiency)
    detergents.
    “F22” (Front door lock)
    Is the washer door firmly shut?
    The door must be completely closed for the washer to
    operate. The door may look closed, but may not be latched.
    Open the door and close firmly.
    Were you washing a large load?
    Before you close the washer door, check for laundry items
    sticking out beyond the door opening. Leave enough space
    in the washer to allow the clothes to tumble freely. An
    overloaded basket may keep the door from shutting
    completely. Reduce your load size if needed.
    Press POWER and select START.
    “F” codes other than F20, F21 or F22
    Select PAUSE/CANCEL twice to cancel the cycle. Select
    DRAIN/SPIN if there is excessive water in the washer.
    Re-select cycle and press START. If the problem remains, call
    for service.
SOURCE:
I have an F28 error what is wrong
As far as I know F28 error code means - SERIAL COMMUNICATIONS ERROR/MOTOR CONTROL UNIT ERROR. Caused by either a communications problem between the Central Control Unit and Motor Control Unit, or Motor Control Unit internal failure.
Jan 12, 2015 | Whirlpool Duet GHW9150P Front Load Washer
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool washer & dryer Duet and my washer keeps getting an error code F21 and recently got F28. I had some work done in the laundry area which caused the washer to be moved and then put...
https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFliXuEuX564wSQ%3D%3D&ddkey=http:AjaxMiniWishListView
Above find a link to your Manual and below find a link to a Video which can assist you in fixing the F21 Error Code
The F28 Error Code could Just be a Fluke But it is supposed to mean that there is no water entering so to be sure before running another load be sure hoses are connected and turned on.
Thumbs up if Helpful and Feedback is Appreciated!!!
Jun 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code f28
Hi, the error code F28 means one or both of these parts are bad.
  • Motor Control Unit (8540135)
  • Microcomputer Machine Control Unit (8540788)
It would be a good idea to order both, as both components have been problematic for error code F28. If you find either the MCU or the CCU(Microcomputer Machine Control Unit) fixed it.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I washed a large load in our Whirlpood Duet Washing Machine and it stopped with a flashing F28 code. I unplugged it for 5 minutes and it still will not run a cycle without stopping with a flashing F28...
The error code F28 means one or both of these parts are bad.
You can download the online repair manual in the below link
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/6545d78b3f479480852571650061b1ba/$FILE/8178558.pdf
On page# 4-20 it shows how to access your MCU.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F35 code
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wahsher
PLACEHOLDER FOR ART
NOTE: If the error remains on the display, then call for service.
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Washing Machines Logo
296 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
