Samsung SGH-i900 Omnia Unlocked Cellular Phone Logo
Kerry Cunningham Posted on Jun 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I forget my password try many cords now there is only numbers 0 to 9 no # and no* keys
RONALD CARTER JR
Level 3:
  • Master 438 Answers
  • Posted on Jun 06, 2011
RONALD CARTER JR
Master
Level 3:
Answers
438
Questions
0
Helped
91561
Points
1345
hi cunningha811 see if you can dial *22890 this should reprogram your phone. for you. hopes this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
I'm forget service mode password in konicaminolta bh 501 con you help me
Bizhub 501 Service mode:
Press utility key
Press Meter count
Press details & then hit stop , 0, 0 ,stop ,0 ,1
Gets you into service mode----
Hopefully , you are not talking about having forgotten the CE password
I foeget service mode password
Entering The Bizhub 361,421,501 Service mode:
Press utility key
Press Meter count
Asking for pin number
How do you change/reset the pin code of Child Lock/Parental Control settings?
  1. In disc mode, press SYSTEM MENU.
  2. Press 060414114420_12548.gif to select Preference.
  3. Press OK to confirm.
  4. Press 060414114406_12547.gif to highlight PASSWORD, then press 060414114432_12549.gif to select CHANGE.
  5. Use the numeric keypad (0-9) to enter your old six-digit password.
    • When doing this for the first time, key in 136900.
    • If you forget your old six-digit password, key in 136900.
  6. Enter the new six-digit password.
  7. Enter the new six-digit password a second time to confirm. The new six-digit password will now take effect.
  8. Press OK to confirm.
3helpful
Hi! Somehow got `Key Locked`on my 42LCD LG TV screen. Can not use remote anymore even to turn it off..Can not find manual to read what should I do in this situation. Could you help? Thanks!
From owner manual:
• If Lock is already set, enter the password as requested.
• The TV is set up with the initial password "0-0-0-0".
• If you ever forget your password,
key in '7', '7', '7', '7' on
the remote control. Then, the
password reset to '7', '7', '7',
'7'.
You should download the user manual: www.retrevo.com
2helpful
I have the first firefly phone from att&t then cincular i am needing to reset password and don't remember the code to do that.
For the Original Firefly Phone:
The default PIN is: 1 2 3 4.
For the glowPhone:
The default Password is: 0 0 0 0
When you first set up your password, you will be able to change from the 0 0 0 0 and enter your own.
If you should happen to forget what password you entered, you can enter the bypass password: 5 6 7 8 and this will then allow you to go into Parental Controls and change your password:
- Scroll to and select Permissions
- Scroll to and select Change Password
You will be prompted to enter a new password, then reaffirm it. You will get a confirmation when the password is successfully changed.
For the flyPhone:
The default password is: 1 2 3 4
When you first set up your password, you will be able to change from the 1 2 3 4 and enter you own.
If you should happen to forget what password you entered, you will need to follow these steps:
- Turn on your flyPhone
- From the Main Firefly Screen, you will need to type in the following (once you start typing, the screen will change): #20070330#
This will restore your flyPhone back to the default settings, so you can now go back in and reset your password.
or try this:
How can I change my phone's Password/PIN? For the Original Firefly Phone:
- Press and hold the green SEND button until you see ENTER PIN. Press Enter.
- Enter your PIN Number by scrolling though and accepting the four numbers you choose. (The default PIN is 1 2 3 4).
- Scroll to DONE and Press OK.
- If your PIN numbers are accepted, the display will say Change PIN.
- Press OK to let Firefly know that you do want to change that PIN.
When the display panel says SAVED, your new PIN is loaded.
For the glowPhone:
For the flyPhone:
Hope this helped.
Source: http://www.fireflymobile.com/
1helpful
2answers
How do I enter the number "0" when entering a password for WLAN? I'm trying to connect to a WLAN using WPA encryption with a password including the number "0" but when pressing "0" it shows up as a star...
Brother's documentation is non-intuitive. Pressing the ' 0 ' key shows a ' * ', but it actually is accepted as a 0 and moves to the next character entry position. Just take it on faith that it enters a 0 when it shows * when entering the wireless key.
I have a BenQ Projector MP610. I lost my password and now i cannot use my projector. I get the code: 22504 13898 6789 8507. Please help...Please email me the decoded password... [email protected]
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right4 for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting > Change Password. 2. Press Left 3 or Right4. A “Password Change” message displays. 3. Enter the old password. i. If the password is correct, you can go on to enter new password. IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __ Keep this manual in a safe place. ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to try again or press Down 6 to cancel. Password Setup Enter Password Press Auto to Confirm Press 5 or 6 to change number Press 3 or 4to move 0 0 0 0 Password Setup Do you want to use 0 0 0 0 as your password? Yes Auto No 5 Cancel
1helpful
I'm trying to set up my voice mail and I am getting a message "mailbox locked". Is there a generic password I can enter that will work? Too, can you send me a step-by-step go-by to set up my mailbox?...
If you recieve the message "mailbox locked" then the password was incorrectlyentered too many times.
To reset your password press feature 983
the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
As far as setting up your Mailbox, press your open mailbox key or press feature 981.
When prompted to enter your password enter the password of 0000.
The voice mail will make you change and confirm your password at this point. your password can be between 4 and 8 digits but cannot start with a 0.
after the password is changed the voice mail will make you record your name for the company directory. once the name recording is accepted, the mailbox will be at your main screen.
To record a greeting for your mail box,
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
3helpful
How do i record new outgoing message ?
From your set, dial: -> FEATURE 9 8 1 -or- the voicemail key -> Put your password in (if this is a new install 0 0 0 0 is your temporary password) -> You'll hear your name and how many messages you have -> now press the number 8
Pressing 8 is to get into the adminsitration of this mailbox, and listen to the prompts. This is where you can change the password, name, greeting. You want to change your primary greeting.
Good Luck!
Reading multi zone DVD's
If you forget your 4-digit code
If you forget your password, to clear the current
password, follow the procedure below.
1. Display Setup menu then select an 1 level icon.
2. Use the Number buttons to enter the 6-digit
number “210499”.
3. Select [Yes] then press ENTER. The 4-digit
password is cleared. Enter a new code.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
