Question about RCA VR355 VHS VCR
Rca vhs vcr model vr355
Vcr will not play, record, rewind, or anything. When I turn it on it stays on a couple of seconds then turns off. My tape will not eject. The clock stays on but that's the only thing that works now.
  • RCA Master
  • 5,568 Answers
The clock uses very little power so a weak supply might still be able to provide stable voltage to it.
All the other functions require enough power to drag down a supply that is on its last legs and I think that is where the problem lays.
If the display brightness seems normal, then either a different section is being used for the missing functions or a weak capacitor in the power supply can no longer filter the DC voltage well enough to provide stable voltage to motors, the main board, etc.
To determine what is at fault will require some technical skills and a couple of instruments normally not found at home.
About the only thing you might try on your own is to open the case, look for a customarily separate board that appears related to the AC input cord which should be unplugged at this time.
You will see cylindrical parts ranging in diameter from 1/4" to about 1 1/4" and various heights.
The tops are normally visible and the cases are of aluminum. Look for any that seem to have bulging tops or a crusty deposit around their base.
Those things are visible indicators of failure.
If you find such parts and have an appropriate soldering iron (not a higher power 'gun') you might remove these and buy replacements.
That could be a problem since most electronics supply places won't even talk to you.
If you want to try on line, look at www.mouser.com , one of the few who will sell single quantities of parts.
The values will look something like this:
100uF/16V
These parts are polarized so if you don't see a '+' or '-' on the board, be sure to mark it before removing so any new part does not fail immediately after replacing.
Posted on Aug 18, 2008
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
My vcr says SAFE how do i get it back into recording mode?
went to RCA site and found manual for my vcr- thank you
Feb 02, 2009 | RCA VR355 VHS VCR
VCR will not play a VHS, just immediately ejects the tape
Please clean its Guides Loading Path and check Loading Belt, if foud lose, replace it,
Aug 02, 2008 | RCA VR355 VHS VCR
Safe!!!
Go inside and REPLACE e v e r y rubber band that u find in machine. Don't replace one or two, if you find one or two bad
REPLACE THEM ALL.
May 23, 2008 | RCA VR355 VHS VCR
VCR
Get thee back to the store. You have a defective TU reel sensor..accordianman
Feb 16, 2008 | Philips VR550 VHS VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
VCR won't rewind
Soution #1 get nice but cheep VHS " rewind " macine.
2nd. Some machines have a special rubber wheel in the center,between the left [ take up or rewind ] & right [ play\record ] assemble. VERY diffiult to repair if u don't know what u are doing.
3rd. Find & REplace EVERY rubber band that u find in the machine.
Oct 18, 2007 | Sansui VHF6010 VHS VCR
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
VCR functions do not work (play, record, ...)
Sounds like the idler assembly isnt working. Without this assembly, the system cannot get the tape to actually move, and most systems will shut down if the tape isnt moving to prevent damage to the tape. In truth, this can be a complicatred repair, requiring the machine to be taken apart quite a bit. I would suggest taking this kind of a problem to a repair shop, but with the cost of simple VCR's coming down constantly, and the upcoming switch to DTV making the machines tuner obsolete, it would probably be more economical to just replace the machine.
Feb 15, 2007 | Mitsubishi HS-U110 VHS VCR
RCA VR355 VHS VCR Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
