Question about Panasonic Televison & Video
My panasonic viera tv has blown its 5amp fuse. i have replaced fuse but now it will not start up the front red light flashes but the fan does not start up and there is no picture can u help
My problem is exactly the same. The TV blew its fuse and will not start again. The front red light flashes when we press the remote but otherwise there is no response.
Posted on Aug 21, 2008
Panasonic Viera TC-37LZ85 powers on with a solid red light that does not blink, the screen slightly illuminates but no picture. Blown fuse?
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 10, 2015 | Panasonic Viera TC-37LZ85 LCD TV
Flashing red light on tv
Depend flashing code ,
7 blinks Sc board bad
10 blink power board bad
Aug 27, 2014 | Panasonic Viera Tc-P42C2 42 in. Plasma TV
I have a panasonic tv CT-34wx54j red light 5 blinks
The power supply probably has failed. The clicks indicate it is trying to start up but can't.
Dec 30, 2013 | Panasonic Viera TH-50PZ85U Plasma TV
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
No picture, power light flashes green. I was watching tv when the picture went out and the power light started flashing green. The temp light did not light up.
If you take the back cover off (and part of the front) you should be able to the cage that holds the lamp. Above that there is a small thermal fuse that occasionally goes out and causes this problem. Quick solution is to repalce with a normal 5amp fuse. Just clip it out and solder the new one in. I would use a pico fuse. Or invest in a replacement thermal fuse from a part store. Part number K5C117BC0003. Goodluck.
Jul 05, 2010 | Panasonic PT-45LC12 45" Rear Projection...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
229 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
