Question about Panasonic Lumix DMC-FZ18K Digital Camera
Lumix Every time I take my battery out for charging I have to reset the time and date when I put it back in....Any clues please
My lumix dmc-lc1 just doesn't want to function suddenlu. no power when you switch it on even if the batteries are fully charge.
Posted on Nov 23, 2008
SOURCE:
How do I put the date stamp on, On Lumix DMC-TZ10 ?
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
Jul 09, 2014 | Panasonic LUMIX DMCZS7 DMCTZ10 Digital...
How do i put a date stamp on lumix dmc-ls80
May 08, 2014 | Panasonic Lumix DMC-TZ50 Digital Camera
Factory reset Lumix DMC-FZ45
Remove the battery for 20 mins. replace the battery.turn on and go to the camera's Menu scroll through the settings to the Date & Time, set the current date and time.
Apr 19, 2013 | Panasonic Lumix Cameras
Lumix dmc-fz100
Remove the battery for 15 mins, replace the battery then go to the camera's Menu and set the Date & Time.
Mar 14, 2013 | Panasonic Lumix DMC-FX01 Digital Camera
Lens doesnt close when switching of the camera bought it today!!!!!!
If lens won't go back, Check batteries and make sure that they have sufficient charge, the batteries may need to be recharged or replaced. follow the instruction to resolve the problem.
--- Remove the battery and wait 30 Seconds & reinsert the battery, if your camera has a backup or date and time battery, remove this battery as well. Removal of the backup battery will cause a full reset of the camera and will clear any settings.
If this will not solve the problem your device need service (repair)
Good Luck & have a nice day
Rating the solution in highly appreciated.
Aug 18, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Camera keeps loosing the time and date settings. When turning the camera on the lens does not open, then a screen asking to set the date and time settings appears - once date reset the camera works...
have you check the settings for time and date have you saved it? You can also try to remove the cam battry for 2 mins. then put it back in then turn on the camera and then after few secs. turn it off, then see if the issue persist.
Feb 21, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Re - Lumix Panasonic DE- 994 battery charger ??
Hi Cyril,
In theory this charger is fully automatic and stops the charging process once it detects that the battery has been fully charged (it will not restart charging until the battery has been taken out + put back in).
Of course, as with any electrical item, it's probably safest to unplug it if you're not planning to use it for a long time (e.g. weeks.)
Hope this helps.
Raf
Jun 11, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
Date not appear on screen
Your internal back-up battery is empty, please replace the internal battery and date will apear.
Rob
Feb 08, 2009 | Panasonic Lumix DMC-FX3 Digital Camera
Cannot turn date stamp off and date keeps resetting
Try removing battery from camera then wait 10 seconds before installing. This action resets camera.
If no work, locate your camera software version. Procedure should be in manual, else could probably find it in a google search. Then locate latest version with a google search, or panasonic camera website, or call to customer service and ask.
It you do not have latest version, ask customer service how to download it.
Jan 20, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Hello pronlem with a panasonic lumix dmc-fx7 battery
help,i have solution panasonic lumix dmc-fx7 lcd blank water damage
Jan 19, 2008 | Panasonic Lumix DMC-FX7 Digital Camera
Open Questions:
Panasonic Lumix DMC-FZ18K Digital Camera Logo
240 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
