Question about Samsung DVDR120 DVD Recorder
Get rid of PSO
Accidently pressed Scan, front panel displays PSO.......
no picture...... only sound.....
How to get rid off this dammed PSO display
Hold the v-scan buton on front panel and you will see the menu for changing the progressive to rgb..
Posted on Mar 10, 2010
  • Mike Jones Nov 12, 2010
    On my Samsung SR150m the button is behind the front face panel and is titled "P Scan". Hold it down for 5 secs or until "PSO" disappears. Then do a search for your input and it should work. You could always take a hammer to it :)
    Problem Solver:
  • 5 Answers
The PSO on the front display has to do with your screen resolution of your tv. I have no idea where my book to my tv is to determine the resolution. I held down the rewind and fast forward buttons at the same time and it disappeared. Clicked on the Menu and checked the resolution again it automatically set it to 480p. I had it on 1080i.
Posted on Oct 18, 2011
Hi guys,
I did it myself, the problem is pure mechanical!
Open cover plate, look behind where the push button of PSO is
located. You see the PSO push-button sort of level-arm somehow sticked to the rubbermatting where the circuit on-off is
located!!
In fact I lodged for advice to Samsung techsup weeks ago, but up to this moment no reply!
Posted on Sep 08, 2008
Did everything : rmoves out cd, put blank cd, record(active), put new dvd to play(active)----all to no avail, still this dammed PSO dsiplay. Audio yes, video no. Did every thing on the push button, to no avail, still PSO display.. No video
Posted on Aug 19, 2008
  • 4 Answers
Take out the CD or DVD inside and check for the display, try putting other dis and check.
Posted on Aug 18, 2008
When PSO button on, the movies won't play
push button p.scan three time with disc out
Apr 10, 2010 | Samsung DVDR120 DVD Recorder
SAMSUNG DVD RECORDXER 120
Do you mean rso on the payer? You should have a button on the front of the dvd maked rso, press this three times to cancel the rso,it should then play.I hope this helps. Jamie
Mar 01, 2009 | Samsung DVDR120 DVD Recorder
Kitchenaid superba stove
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
The Control Lock is preset unlocked, but can be locked.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
appear on the display.
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Sep 29, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
I accidently changed the language now its in dutch i think
Troubleshooting steps to be Followed
Setting the front panel language on the HP PSC 2200 series To set the language and region, follow the steps below:
  1. On the all-in-one front panel, press the Setup button five times, and then press Enter to access the Maintenance settings.
  2. Press the number 5 on the front panel numeric keypad, and then press Enter to access the Language and Region settings.
  3. The available languages will appear in the display. Press the Right Arrow (>) button to scroll through the available languages. Enter the two-digit code for the desired language based on what is listed in the display (example - 11 for English, 12 for Spanish, and etc.).
  4. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the language and try again.
  5. The available regions will appear in the display. Press the Right Arrow (>) button to scroll through the available regions. Enter the two-digit code for the desired region based on what is listed in the display.
  6. Confirm the selection by pressing the number 1 on the numeric keypad of the all-in-one. Press 2 to cancel the region and try again.
The front panel language does not set correctly There can be a problem if the front panel cover (bezel) is not installed correctly. If the language cannot be set or is still wrong, do the following:
  1. If the software has not been installed, install it.
  2. Remove the control panel bezel. This may require the use of a coin or small screwdriver to carefully pry up the cover from the back (near the display).
  3. Reinstall the front panel bezel as shown in Figure 1. Be sure the bezel is firmly seated and that all of the buttons can move freely. Figure 1: Installing the front panel bezel c00224430.jpg
  4. Set the front panel language following the steps above.
Sep 18, 2008 | HP PSC 2210 All-In-One InkJet Printer
PSO
Make sure the Progressive scan is not on if you are using RCA out(yellow/white and red cables) check the dvd screen to see if there is a P
Jun 16, 2008 | Samsung DVDR120 DVD Recorder
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
My pioneer xv htd330 is set to progressive scan and i need to change it back to interlace, but i can't see the menu on my tv. is there a way to reset it to factory settings
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on
Feb 28, 2008 | Pioneer Televison & Video
Progressive scan
From the manual:
Press the front panel >/II button to set to interlace & switch the system back on.
Feb 27, 2008 | Pioneer HTD-330DV System
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
Samsung DVDR120 DVD Recorder Logo
1,107 people viewed this question
Henry  Thomas
Henry Thomas
