Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Ice maker not working
All of a sudden my icemaker is not working. The water does not seem to run through the ice maker. I used to hear it now I do not hear the water running . What can I do to make it run again?
  • nikog Aug 30, 2008
    filtered water is working ok
    however the ice maker is not, it appears that the water is not getting to the ice maker
    I took the ice maker out and the water supply hose had ice build up -removed ice and thawed further with hair dryer
    still water is not getting to ice maker
  • Anonymous Jan 25, 2009
    no water coming out of filter. tried new ice maker an filter still not working
  • 126 Answers
HAVE YOU CHECKED THAT YOUR WATER VALVE IS WORKING OK.IF THATS WORKING YOU MIGHT HAVE A PROBLEM INTERNLY ON THE ICE MAKER HAVE THAT CHECKED BY A TECHNICIAN.GOOD LUCK.MOHAMED
Posted on Sep 12, 2008
Adjustable icemaker not making ice
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
May 11, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Icemaker not working
The ice maker valve is a dual one. with 2 solenoids. One solenoid operates the water and the other the ice maker. So if the water works that don't mean the ice maker supply is ok. The ice maker itself controls the flow of water. So if the water valve is ok then the ice maker is faulty. I have repair photos HERE
Feb 14, 2010 | Refrigerators
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
Sep 14, 2009 | Refrigerators
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Water line flows freely on my msd2454gr - freezer is cold - ice maker seems to have electricity to it to levers move and the ice maker lever moves - but never hear water going to the ice maker - i have...
Hi, Yes you can. When the icemaker cycles, do you hear the inlet valve buzzing? If you blew through the line that goes from the inlet valve to the icemaker and it is open, sounds like the inlet valve is bad.
May 17, 2009 | Maytag MZD2766GES Side by Side...
Ice maker
your plastic water tube coming in to the icemaker is probably frozen needs to be taken out and remove ice not letting water come in to icemaker I have run on this alot in the field.This seems to happen [alot] when you turn off the water to the icemaker
Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer Not making ice
are u getting water to the icemaker? If Not check water valve for ice maker in back of refrig.
Sep 11, 2007 | Sub-Zero 650 / O Bottom Freezer...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
111 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
